*warning for everyone with umnitza angel eyes*
Old Jan 19, 2006 | 11:10 PM
Clayton1's Avatar
Default *warning for everyone with umnitza angel eyes*
Alright if yall have the umnitza angel eyes, I have some news for you. If you, like me, mounted your ballast on the underside of your headlights (sorry if you did that b/c it said so in my DIY) GO TAKE THEM OFF NOW!!! Water will get into your ballasts and destory them. I already lost both of my ballasts. I call umnitza today and talked to them and they said that we need to mount our ballasts to the upper radiator support beam. I haven't had a chance to go and look under the hood of my car so I;m quite sure where they mean, but I just wanted to let yall know so no one has to go without rocking their totally badass demon eyes for a few days while they wait for a new ballast. Maybe someone who have the demon eyes installed by Umnitza could post a pic where they mounted the ballasts so we could get a better idea???
Old Jan 19, 2006 | 11:24 PM
maximus96's Avatar
FYI: those are actually inverters...not ballasts...
are they sending you new ones? you can buy a cheap set of ccfl lights from www.svc.com and use the inverters from those...cost you like $5...
Old Jan 19, 2006 | 11:58 PM
ycart1201's Avatar
i dont have them, but this is good to know...
Nathan
ycart1201
Old Jan 20, 2006 | 01:53 AM
Clayton1's Avatar
they are sending me new ones, but i doubt they will do it for many other people
Old Jan 20, 2006 | 04:50 AM
Kakashi_s1's Avatar
Where's the ballast/inverter located? I thought everything was sealed when re-baked? I have no idea yet. I just bought those demon eyes and should receive it shortly. I don't want any trouble coming from it. Can you post a picture up of the location where water leaked at? Thanks.
Old Jan 21, 2006 | 05:15 PM
tcholic's Avatar
it goes under the metal beam thats located over the headlight......i just installed mine yesterday.......its raining over here and no problems so far
Old Jan 21, 2006 | 05:27 PM
SciontCya's Avatar
Big Sky Scion
Aren't the ballasts sealed?
They should be.
If not, I'd take some silicone glue and make sure they don't leak.
Changing location is not a fix - what if you detail your engine/bay?
I find it odd that something like that is not water-tight...
Scott
Old Jan 22, 2006 | 07:03 AM
tcholic's Avatar
^ yea, they arnt water tight....the cover can pop right off.....
Old Jan 22, 2006 | 04:57 PM
SciontCya's Avatar
Big Sky Scion
That would pi$$ me off!
If someone makes a piece like that and it's not water-tight, I have to wonder about their product's engineering.
That's cheap, and stupid.
Scott
Old Jan 23, 2006 | 12:56 AM
taek's Avatar
wedrivescions is at my house right now and he said
"yeah yeah, i already went through 3 ballasts becuase of that"
Here's the deal.... Take the rubber spray you can buy at an auto store, used to spray the handles of tools and such and spray the whole ballast, let it dry, and then spray it again.... TOTALLY watertight.
Also, be sure to wrap the connections between the ballasts and the DDE Rings, as water can get in there and bridge the connections, shorting it out again...
Then you can moun them anywhere... and not have to worry about water.
Old Jan 23, 2006 | 02:27 AM
Clayton1's Avatar
ahhhh awesome idea taek. thanks man
Old Jan 23, 2006 | 03:08 AM
jwaggz82's Avatar
how hard was it to install the angel eyes?
Old Jan 23, 2006 | 04:13 AM
markritch's Avatar
yea they arent ballasts they just inverters for power....they are pretty cheaply made, and you can get a pair of cathodes like maximus said off SVC.com or xoxide.com and they come with the inverter, simply connect that the same way this one is and your good to go.....ive had bnothihng but probs with my inverters since i had them, both my passenger side rings arent working now ____es me OFF
also keep them away from mounting them on the metal of the car...it screws them up and dims them untill you move the ballast
Old Jan 23, 2006 | 09:22 PM
davedavetC's Avatar
same thing happened to me but im getting new ballast, and think im gonna do what taek said about the spray, but does anyone have more info about that stuff? like names of it and where to get it?? thanks
Old Jan 23, 2006 | 09:24 PM
Clayton1's Avatar
Does anyone think that there is a enough room in the back of the headlight to put the ballast inside the headlight??
Old Jan 24, 2006 | 01:52 AM
davedavetC's Avatar
i dont know if that would work, would the ballast be able to handle the heat you have to apply to the headlamps to put them back together??
Old Jan 28, 2006 | 08:18 PM
markritch's Avatar
put them in plastic bags
babyfac3pn01
Oct 19, 2015 07:24 AM
umnitza
Sep 1, 2015 08:06 PM
stayintrucha
Regional - Pacific South
Aug 27, 2015 05:01 PM
umnitza
Aug 21, 2015 12:35 AM
umnitza
Jul 25, 2015 07:54 PM
