04-29-2004, 05:16 AM
So, I have been gettin a lot of questions and scions showing up with messed up TRD mufflers burning their bumpers. And I decided to investigate and found that there is an exhaust gasket that goes in between the muffler and pipe. Special order from toyota, and is covered by toyota.(If you had the dealer install the muffler) If you installed your own muffler and the gasket goes bad then you need to pay for a new gasket yourself.
Muffler burning the bumber.
http://www.superford.org/getfile.php?id=120174&toggle=fullsize&f=atech1.jpg
New gasket (part#90917-06082) and old gasket
the new gasket is flat and not cone shaped.
http://www.superford.org/getfile.php?id=120175&toggle=fullsize&f=Atech2.jpg
when you install the new gasket you have to pull down on it to shape the pipe. So after you pull down on it the gasket is cone shaped.
http://www.superford.org/getfile.php?id=120182&toggle=fullsize&f=Atech3.jpg
After the muffler will be centered again and you will have a burnless bumper again.
http://www.superford.org/getfile.php?id=120177&toggle=fullsize&f=Atech4.jpg
Thanks to Maddworrx for allowing me to show his set-up to you.
