Oznium Cathodes???
I'm thinking about buying some 12" ones but I'm stuck between white or red? I REALLY want the red ones but I read a testamonial on their website and someone stated that their "red" is more like pink? If that's the case, I might have to go with white but I think that might be WAYYY too bright inside. Does anyone here have Oznium's red cathodes in their Box and is it really red and if possible can I have a nice clear photo of your interior with them on...Thanks a million...
not mine but these are the same cathodes that oznium sells..... they are absolutely identical except the transformer os light blue instead of black and it does not say oznium on it but this guy spent $14 bucks for the same thing
i have white ozniums under my hood.....6 of them.... they are great..... i remember seeing somewhere that the ozniums were the only ones someone found that were not pinkish red
I'll say the red CCFL tubes Phil has to offer are red, but they do have a pink color to them. If you are worried that much about making sure they are red and not pink, then I would recommend going with dual 12" red LED tubes instead.
Originally Posted by dredge38
ive got red ones from oznium sells and they are still alittle pink i havent installed them yet cause im still decideding if i want to go with leds instead
if your getting blue i would go with cathodes, there so much cheaper and i think there brighter, every color is great with cathodes expect red, the red is getting better but its still a little to pink, id go with cathodes if your gunna do blue
how can you go about installing these, i should be expecting my white ones to come in anyday now,
can i just tap into the cubby hole light if i want them to come on with that?
and how do you hook them up to a switch? sorry im a newb when it comes to this stuff.
and should i unhook the battery for this?
Originally Posted by hornet_on_flower
yeah bad thing about cathode's is you can't dim 'em with a dimmer switch unlike leds which you can use a dimmer switch
If you still run into trouble, or have questions, you can call me and I'd be happy to help. 800-245-8131 or if I don't pick up there, try my cell: 925-683-1839
Originally Posted by Spr0ket
You can dim them.
i got some dual red and they are a red orange color....does anyone know what you have to do to the inverter and light to put them outside of the car? Like underneath and in the engine bay.....the inverter has like holes in them for cooling i think and if you seal them up with silicone or something wouldn't it overheat.
