View Full Version : What spark plug are you FI xB's using
Baine
01-20-2006, 02:44 PM
I was told by the Blitz USA folks to run a one degree cooler plug once I got the SC
installed. I decided to go with the NGK Iridium plugs. I had to special order them.
The only place I found that even carried NGK was Advance Auto Parts. The stock
Iridium number is BKR5EIX. One degree cooler is BKR6EIX. They just came in
yesterday, so I'll put them in tonight and let you know if I see any improvement.
What are you running?
Simplyscion
01-21-2006, 04:56 PM
Try cross refrencing those plugs to some copper plugs...they are really cheap...like $2 and they work the best with boost. You gotta gap them different than the stock gap though...like a .025.
Xbilly
01-23-2006, 10:26 PM
I will be running Blitz Irridium Spec77 T7340B-8
thats what came with my kit.
Baine
01-23-2006, 11:00 PM
I read somewhere that the blitz plugs are made by NGK. On a side note, the car went in today for the new clutch.
Xbilly
01-24-2006, 07:35 AM
U getting the greddy kit for your rs3?
I want an rs3...
with a greddy sc...
Baine
01-24-2006, 11:24 AM
I want an rs3...
with a greddy sc...
Only if you have six very lucky lottery numbers for me. The wifes car will be mostly stock.
bBoxed_In
01-28-2006, 04:50 AM
typically w/ any boosted car that didn't come stock turbocharged/supercharged just to be on the safe side you'd probably want to run a 1 step colder plug. 2 step maybe a little overkill if you're not running higher boost levels or higher levels of compression.
as a note, some cars run great with copper plugs, some cars don't. most subaru guys will swear by coppers while some other manufacturer's turbo cars won't run the greatest with them.
seattleplasma
02-02-2006, 06:35 AM
dont mean to aska stupid question. buuut what happens if you run that plug on a car with I/H/E would i see a diffrence the regular plug not the 1 degree cooler plug.
bBoxed_In
02-06-2006, 05:05 AM
with minor bolt-on's like that don't waste your money. a good set of stocks will work just fine when the old ones crap out on you.
uberscionofglendale
02-07-2006, 02:51 AM
yeah, and you should have 120k i think on the stock ones.
metsvenand
09-29-2006, 06:12 PM
When I was racing my eclipse gsx, it was recommended for each gain of 75-125 HP to go 1 colder spark plug. I would still recommend to go 1 colder spark plug with a supercharged or turbo Xb. Not for I/H/E.
iceboxx5
02-28-2007, 11:40 PM
I had my greddy sc installed 3 weeks ago with the stock spark plugs.I put the ngk iridum bkr6eix plugs in today. " NASTY"
EasysBox
03-06-2007, 12:03 PM
always drop a heat range when you boost your car. or increase the boost. colder plugs mean less chance of detonation, but will dirty faster. id rather change my plugs more often than replace my motor... does anyone have the part number for NGK copper plugs one heat range colder?
proctorsilex
05-08-2007, 03:11 AM
i just got the BKR6EIX.
what gap are you using?
have any of you experimented?
i have the blitz SC, btw.
thanks
panda-JORDANxi-box
05-10-2007, 09:21 AM
ngk
JSosa
05-10-2007, 01:18 PM
NGK Iridium...
proctorsilex
05-11-2007, 09:01 PM
so you guys are using the stock gap then, eh?
anybody tested for optimum?
Simplyscion
05-11-2007, 09:23 PM
i used to gap em at .025 and the plugs were one step colder
proctorsilex
05-12-2007, 02:31 AM
^^ thanks, man. any particular reason for 0.025"?
for everyone's reference, stock is 0.028-0.031" (0.7-0.8mm).
EasysBox
05-12-2007, 10:50 AM
increase in atmosphere makes it more difficult for the plug to spark. i had that problem with my GP when i changed the supercharger pulley, it made it misfire in the higher RPM's when boost was at its peak, 12psi, because the plugs weren't able to spark, gapped them down and it ran great...
Sci0nXa
06-28-2007, 03:59 PM
this thread is pretty unclear. I just bought the ngk, Can anyone with the ngk's verify what to gap them at? is it .025
Simplyscion
06-28-2007, 05:01 PM
yea, thats good
Sci0nXa
06-28-2007, 08:30 PM
Thanks! :bow:
proctorsilex
06-28-2007, 09:23 PM
0.030" has worked well with the blitz for the two months since i installed it.
JSosa
06-29-2007, 06:36 PM
Are these the plugs you guys are talking about??
http://ngk.carshopinc.com/product_info.php/products_id/40840/BKR6EIX-11
proctorsilex
06-30-2007, 02:39 AM
^^ looks like what i have
Sci0nXa
06-30-2007, 04:39 AM
Mine were 6.99 each at autozone
proctorsilex
06-30-2007, 05:18 AM
mine was similarly priced at pewp boys.
for the record, there was no dramatic difference after i switched. but i have had misfires near red line when pushing really hard on warm days with these plugs. i imagine that it would have been worse with the warmer stock rating plugs.
jsosa, you have been silent for a while. everything ok?
JSosa
06-30-2007, 04:29 PM
its all good. I was at Indy watching the F1 Race last weekened with my dad and brother. And when i got back i was having my computer reformatted and it took a little longer than expected.
Just to update, Todd sent me the last of the turbo components, so hopefully i will be boosting soon.
