what exhaust pipe width do you'all have?
Old Jan 20, 2006 | 11:49 PM
danman2_2999's Avatar
Default what exhaust pipe width do you'all have?
hey i got an exhaust system slapped in a while ago, and they put three inch pipes, but i seemed to have lost some power. so the other day i was backing up and there was this little _____ ___ curb like thing sitting on the ground, and it hit my exaust so ima get it redone, but i wanna kno what size i should be getting.
thanks!
Old Jan 20, 2006 | 11:50 PM
stick_1NZ's Avatar
I got a custom-made 2.25". 3" seems too big, you'll lose power definitely at the back end.
Old Jan 20, 2006 | 11:51 PM
sexyscionlover's Avatar
i have 2 inch from cat/axle (a mix in between. not all the way to cat, but farther than axle) to the tip. (no muffler). Power feels good and it sounds growly!
Scott
Old Jan 21, 2006 | 12:03 AM
i think they put three inch pass the cadylitic converter to the magnaflo exhaust tip i have. it sounds decent but i remember when i got it first installed i thot i felt loss power. so if a custom 2.25 inch is not available, should i go back to the stock 2 inch?
Old Jan 21, 2006 | 12:07 PM
dexter_5000's Avatar
3 inch and larger is only useful if you have a turbo where you are trying to get it to flow better since it gets hotter.
for your application 2 inch or 2.25 max diameter unless you plan on boosting if you go with a slighty more restrictive exhaust you'll notice an increase in tourque again. designing an exhaust is not easy cause you need the best possible flow. with the ability to retain heat in it to increase the velocity.
Old Jan 31, 2006 | 03:38 AM
so how does it sound without a tip? seems like it would sound "broken" or way too loud. anyway, i wanted to get a double chrome tip, but i havent seen any that can fit in the little hole! anybody kno where they sell tips like this one:
http://cgi.ebay.com/ebaymotors/2003-...spagenameZWDVW
i suppose with that kit, the hole is a lot bigger. but anyway, does anybody have the double exhaust (not dual like in the pic, but just one side, but two). thanks for the help
Old Jan 31, 2006 | 04:02 AM
SXT_HuntToKill's Avatar
DelMarVa
i have a custom bent 2.5" i felt a loss of power as well but that changed when i got my header and intake... kinda feels the same when it was all stock now... just with a kick in the torque range of rpms .... from 3500 to 5000... but if i had to do it again i would prob go with a 2.25" or a 2" stock is 1.5" up to you bro
Old Jan 31, 2006 | 03:56 PM
ctruss's Avatar
You can't go back to the stock 2" exhaust because the stock exhaust is a pittifully small 1.5" from the resonator back.
I custom built a 2.25" mandrel bent exhaust system from the cat-back to the muffler. The at the muffler it expands to 2.5" for more muffler options.
If you go bigger than 2.25" you will lose all your torque. You will make a couple more hp, but you won't see them until you spin your engine over 5000 rpm.
Old Feb 1, 2006 | 03:21 AM
and these custom pipes....are they expensive or what? anybody know about the double tip??
Old Feb 1, 2006 | 03:23 AM
DelMarVa
mine from my local shop was $120 that include hangers and putting my tip on
Old Feb 1, 2006 | 03:38 AM
rogcjms's Avatar
NM SCIONS
ok heres my question. i have the DC Sports axle back system on my RS 2.0 since it already came with it but what I wanted to know is if I can upgrade the piping from the muffler back? anybody know what the DC sports piping size is? I figured 2.25-2.50" would be the best size for the new piping? let me know asap. Thanks
Old Feb 1, 2006 | 04:00 AM
hotbox05's Avatar
2.0 is best. 2.25 is for say a s/c . 2.5 is pretty much the largest u can put on a highly modified turbo . any more and bye bye power.
Old Feb 2, 2006 | 02:56 AM
rogcjms's Avatar
NM SCIONS
are there any parts of the exhuast that I cannot remove?
Old Feb 2, 2006 | 01:18 PM
DelMarVa
well depending on your state the to cats that it has can either come of or stay on but wouldn't do it.... i was thinkin about it too but im happy with the way my box sounds and drives with them on
Old Feb 3, 2006 | 02:40 AM
hotbox05's Avatar
cats are illegal in the entire nation. federally mandated. but some states that doesnt matter.
Old Feb 3, 2006 | 03:38 AM
OEMxB's Avatar
I dId WhAt squirrel DiD, 2 1/4 iNcH fRoM tHe ReSiNaTeR bAcK.
Old Feb 3, 2006 | 04:53 AM
xAlex's Avatar
I got the magnaflow, 2.25" from the cat-back, the tip is 4" and i've only gained power after having this put on. i planned on a s/c in the future...
Old Feb 3, 2006 | 05:46 AM
05-RS1's Avatar
i think for tc's, the stock midpipe is like 2.36 or sumthing. imma get 2.5 whenever i'm ready
Old Feb 3, 2006 | 01:21 PM
JSosa's Avatar
I put 2.25 on my car with an InVidia axle-back. Of course i didnt chop down my whole exhaust i still left the cat and the resonator and pretty much all plumbing in between, but what i did do was make the axle-back into a cat-back and ran a nice header and the power is nice... I dont think chaning the whole exhaust system will give much more of a power change, but whatever you dont make in power you will make in NOISE!!
Old Feb 3, 2006 | 11:05 PM
xAlex's Avatar
Originally Posted by JSosa
...i didnt chop down my whole exhaust i still left the cat and the resonator and pretty much all plumbing in between, but what i did do was make the axle-back into a cat-back ...
How is that possible? making a 'catback' w/o doing any cutting, especially on an xA?
