possible to change bolt pattern?
Old Apr 30, 2004 | 05:57 PM
MIKEY's Avatar
Default possible to change bolt pattern?
Is it possible to change a bolt pattern? I know that it would takea serious amount of work, but has anybody ever seen it done? Thanks for the help
Old Apr 30, 2004 | 06:00 PM
GeniusGZA's Avatar
im in the process of trying to do this too, i would think you would just change the hubs :?:
Old Apr 30, 2004 | 06:23 PM
Silencei2's Avatar
Default Hub
Yea, all you do is change the hubs which require finding other hubs like the xB. I know from my research on Integra Type R's (since the Type R has a 5 lug bolt pattern and any other model has the 4 lug bolt pattern) that changing the hub is all you need to do but finding a similar hub would be the problem
Old Apr 30, 2004 | 07:51 PM
ghost's Avatar
N.G.S.O.
You will also need new rotors.
Why not just buy adaptors?
Andrew
Edit: Brain Fart
Old May 1, 2004 | 12:07 AM
dub_box's Avatar
Default don't need adapters
Why would you like to change the bolt pattern? What real significance could it make anyway? to answer your question= try the 2003-2004 Corolla S model. It is 5 on 100mm and everything should bolt up clean. You will end up with larger front rotors but still have drums and the rear.
Old May 1, 2004 | 12:22 AM
TheRedBox's Avatar
exactly what i was thinking.
Old May 1, 2004 | 04:31 AM
djimpak's Avatar
Default Re: don't need adapters
or you can convert the rear drums to disc..
Old May 1, 2004 | 05:50 AM
chobits's Avatar
so where to buy this "adaptor" thing?
and how much is it?
I wanna get my friend's Volks LE-37 off his Prelude
He sold his car
Old May 1, 2004 | 06:37 AM
dub_box's Avatar
[quote="chobits"]so where to buy this "adaptor" thing?
and how much is it?
After you buy a 1 1/3" adapter (if you could find a 4 lug to a 5 lug adapter) where on this God's earth could you find a wheel with a +70mm offset.
Don't listen to this adapter BS, I sell them and I am here to tell you the application won't work.
Old May 1, 2004 | 03:03 PM
ghost's Avatar
N.G.S.O.
Andrew
Old May 2, 2004 | 07:11 PM
tinybigrig's Avatar
firts, why do you want to change? i hope its not to find more rims that fit.....cuz if thats the only reason thats just a waste of money. if you want rear disks you can swap them out of an older carolla gts like slowpoke did, or get some willwoods, of course i could never afford that....but its a nice thought
brent
ps hey guys i was thinking of the bombnst swap ever, just visualize it, front drums!
Old May 2, 2004 | 07:36 PM
DJ_SpaRky's Avatar
Talk about Old Skool.
Anyways, If you really want to do anything, do it right the first time, I agree with dub box, do a complete rotor/hub/drum swap to get 5x100 bolt pattern, but you're still looking at the same kinda wheel as 4x100, as both are Japanese.
Just my $0.03 short of a Nickel.
:twisted:
scionlife
371
Jun 2, 2015 11:00 PM
Deves
Feb 8, 2015 11:37 PM
ScionVan
27
Jan 19, 2004 05:00 PM
Rukus_Ed
Nov 6, 2003 02:03 AM
