xA cig lighter where the heck is the wires!
Old Jan 26, 2006 | 04:03 AM
xternal's Avatar
OhioScions
Default xA cig lighter where the heck is the wires!
Ok I spent the past two hours looking for a thread on how to get to the wires for the cig lighter on an xA. Obviously looking to tap into power for some under dash lighting, will work off switch yada, yada no issue... Problem, I can't seem to locate how to get to the wires on my xA it is not the same as xb or tC and I am sleepy now... I am pretty good at this, just new to this car.
Old Jan 26, 2006 | 04:21 AM
uber-xA-RS2's Avatar
The wires are there, they are just hidden a bit. To get to the wires you need to remove the two vertical silver trim pieces on either side of the center console. Once that is complete you will notice that the center section of the dash is devided up into sections, the "oven", the ashtray/lighter compartment, and the lover storage bin. The ashtray/lighter unit is held in with friction clips, generally all you have to do is CAREFULLY pull the unit out. Pulling too hard may rip the wires out of the lighter unit.
I used the lighter wires to hardwire my Radar Detector into my car.
Old Jan 26, 2006 | 04:23 AM
jct's Avatar
jct
here ya go
https://www.scionlife.com/forums/viewtopic.php?t=37733
Old Jan 26, 2006 | 04:26 AM
jct's Avatar
jct
mine is held in with two screws, the bottom cubbie is held on with the friction clips
Old Jan 26, 2006 | 04:33 AM
Thanks hornet! Couldn't remember if it was screws or clips, so I went with the clips.
A #2 phillips screwdriver and a light tug of the unit and you should be good to go, xternal!
Old Jan 26, 2006 | 12:36 PM
xternal's Avatar
OhioScions
Thanks. I was thinking I was going to have to remove the silver trim. I have been a little hesitant because I tend to break plastic peices. I am not a very good interior worker. I'll build up some nerve this weekend and see if I can give this a shot.
Thanks guys!
Old Feb 16, 2006 | 02:40 AM
xternal's Avatar
OhioScions
ok so I gave this a shot, and shorted out the radio and lighter justa fuse so its all good. I am thinking of moving to an empty fuse and grounding on a screw underneath somewhere any suggestions would be apreciated. Also while I there was wondering, if I ran a wire from the positive terminal on the new switch I have to the oven light positive, will this work?
Spitfire23
Scion tC 1G ICE & Interior
Sep 8, 2015 03:31 AM
Wrencher
Jul 29, 2015 01:38 PM
Mica09
Jul 25, 2015 05:28 PM
Bish80
Jul 24, 2015 02:02 AM
StxArOne
Jul 13, 2015 06:25 PM
