Low Offset Report
Old Oct 29, 2003 | 06:42 PM
Opr8r's Avatar
sIcKsCiOnS
Default Low Offset Report
I'm currently have the 5Zigen 2.1" drop and I'm running the 5Zigen M05's (17x7 +25) with 205/40/17 tires. There's no rubbing at all. So anyone interested in a similar setupshould have no worries!
Peace,
m@
Old Oct 29, 2003 | 06:45 PM
bBted's Avatar
matt...u just making everyone jealous.... :D
oh yea, hows your car? in the shop?
Old Oct 30, 2003 | 05:24 AM
squirrel's Avatar
thanks for rubbing it in m@!!!!!!!!!!!!!!!!!!!!!!!!
squirrel
Old Oct 30, 2003 | 10:00 PM
avus's Avatar
sIcKsCiOnS
those the same wheels Van is selling? I'm also gettin myself a set -- hyperblack.
m@, do the front and rear line up the same or is the rear further in the well?
Old Oct 31, 2003 | 04:06 PM
Opr8r's Avatar
sIcKsCiOnS
Those are the rims that Van is selling. The front is dead-on flush with the fender. (Looks sweet at a 3/4 angle) The rear is slightly in the well, but I think a 5-10 millimeter spacer would do the trick. I haven't put any spacers on yet.
Peace,
m@
Old Nov 1, 2003 | 11:34 PM
ScionVan's Avatar
The Scions-both xA and xB-can take a lot more meat in the back, and the one downside to running low offset wheels that are so flush in the front is that, since the front is now straight flush with the wheelwell, you can see how much more room you have to go in the back! This is only an issue if you are running all four wheels of the same fitment, and can easily be solved with a 5mm spacer. To make it just as flush in the back as the front though, you'd need something closer to 9-11mm (there's just under a hair of 1/2" different in the rear it seems), but a 5mm is the safest maximum thickness spacer I'd recommend running on stock wheel studs. Here's a pic that demonstrates what I mean about the difference in the wheelwells:
Old Nov 3, 2003 | 01:57 AM
Guest
Guest
Posts: n/a
Such a clean set-up mat, Thanks for bringing it to the shop so I could see it.
KILLER
Mar 29, 2015 05:32 PM
Besk_one
Scion xA Aero & Exterior
Jan 6, 2004 08:03 AM
Opr8r
15
Oct 6, 2003 05:07 PM
smilygo
Oct 1, 2003 07:03 AM
TJ
Sep 29, 2003 06:52 PM
