Need Advice....tC Bolt Pattern?
so my car was recently involved in a wreck and my 2 rims were damaged, so I am getting a check for a 1K the cost of the 2 rims through Scion and thinking of going aftermarket.
Now my buddy is selling some 19's off his IS300 and he thinks the bolt pattern is the same and he says the bolt pattern for the tC is 5 X 100 in which they will fit 100 and 114.3
Just curious if this info is correct.
Here is the link to the rims: http://www.revwheels.com/m2.html#
Hyperblack with polished lip. It's a hell of a deal if they can fit.
Also will the tires fit my ride. Falken Azenis 215/35/19?
TIA.
TIA.
114 will not work on 100's . That number is the diameter of the bolt circle (a circle running through the center of each bolt hole. You would be trying to place a wheel with bolt circle diameter of 114mm on a hub with a circle of 100mm. Thats over a half inch difference
will most stock tires fit on aftermarket rims? or no? because am looking to get rims w/ no tires and put the stock ones on so that next winter i will just buy winter tires for the stock rims.
depends what size your aftermarket wheels are going to be. it might fit, it might looked stretched, or it might look like it has love handles. and thsoe wheels look like they're universal. i'm not sure but i thought those with 10 holes in the center was made to fit both 5x100 and 114.3
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
crimson_sinn
Sep 25, 2015 09:41 PM
SJMiller
Sep 12, 2015 06:33 PM
