Has anyone ever done this themselves?
I was wondering if anyone has ever put on the springs themselves? and how hard it would be. I am getting the TRD springs but I basically have 2 options for installing them where im at, one place wanted to charge me 360.00 just to install them, and the dealership here wants to charge 260.00, is that the average price?
Thanks for any help
Thanks for any help
Here are the instructions for the spring install. You'll have to decide if you're capable of putting them in.
http://www.club-tc.com/forums/suspen...k-install.html
http://www.club-tc.com/forums/suspen...tallation.html
springs are fairly ok as long as you have a compressor.. i tried without one.... didn't go too well. reasonable prices for installs are more like $100... those prices you listed are way too much..
Originally Posted by Reese
^^ the $260.00 price is actually from the toyota/scion dealership here
Music City Scions
Originally Posted by GWARtC
Those of you that have springs installed and still have stock shocks; have you had any problems with the shocks yet?
I have noticed the ride quality degraded futher than I thought it would. Dealer told me the spring rates were only 10% greater than stock, but of course they're actually a bit more than that. Now feel all road irregularities, such that the ride seems a bit rough, and still have too much body roll. Need to add the TRD rear anti-roll bar for better handling, but am sure that'll degrade ride quality even further.
anytime you do spring's on this car it is a good idea to do the shock's when you lower the piston into the shock body farther than stock you will shorten the shock life faster. as for trd spring's and sway bar degrading ride quality i would say that better handling would be an upgrade not a downgrade. but some people might not like the firmer ride that the trd suspension give's
However, I've never heard of a scenario such as this causing the shocks to wear out faster simply because the piston is further into the body than stock. Sure there's additional risk of bottoming out due to having less remaining travel, which can damage the shock, but other than that I don't see why it'd wear out faster.
Care to elaborate?
if you do a search online you can find why when the piston run's lower in the stroke it decreases shock life. but basicaly it causes the shock to run hotter and wear prematurly. that is why the trd shock's are shorter than stock.also as long as you have the bump stop's installed on the shock than you should not have a problem with bottoming out.
Music City Scions
Originally Posted by ceeelotee
my local dealer charges $650 just for installation alone ...
its easy man.1. compress springs 2. loosen/remove nut on top. 3. remove stock sprinng. 4. drop in trd ones 5. compress and install nut.6. remove compressor and install back on car.7. alignment. 8. enjoy
(Even though it's an old thread, just felt I had to say this.)
So my friend and I installed my S-techs yesterday. We started at 1pm. We finished at midnight...
Yeah, I know it should have only taken 3-4 hours, but neither of us had ever done it before so it was a learning process. Plus, we were lacking in certain tools that made the job more difficult for us.
PRO TIP!!! Be sure and have a 22mm socket on you before you start. We initially tried using a 3/4 socket on the bolts that connect the shock to the control arm for the front wheels, and found out there is just a tad too much "play". The 22mm socket is .2mm smaller then the 3/4, which actually makes a huge difference. Also, have a torque wrench on hand that can do a good 150-200 foot lbs of pressure. Ours only did 100 and made our lives more difficult...
Lol can't believe it took us 11 hours hahahahahaha
