205/50-15 vs 205/55-15 on a 15x8
Old Feb 3, 2006 | 02:52 AM
Burn0ut's Avatar
Default 205/50-15 vs 205/55-15 on a 15x8
will there be a substancial difference as to how a 205/50-15 and a 205/55-15 on a 15x8? I want it to be a little stretched, but a 195 or 185 tire will hinder driveablity (rougher ride and making the car way lower)...although i know it would look bad ___ . so yea I want to stick with a 205 tire...which is a better fit for what i want? and any one with pictures?
Old Feb 3, 2006 | 02:59 AM
fachiro1's Avatar
Old Feb 3, 2006 | 03:48 AM
Burn0ut's Avatar
thx for the pix...thats 205/50-15 right? will 205/55 look a lot different? how much lower did it make your car than stock?
Old Feb 3, 2006 | 04:04 AM
OEMxB's Avatar
I'd Go 205 FiDdY.
Old Feb 3, 2006 | 05:20 AM
fachiro1's Avatar
yes, 205 50 15 kumho.....the kumho side wall is kind of round and doesnt look as good as say a toyo . it's a noticeable stretch, you gotta see it in person to see, but it's not extreme. i will say this though....by going to the 8 inch wheel....ride will suffer anyways....not much difference noticeable betweenthe 205 and 195. also, if you get a low offest (mines +10 on the rears +25 up front) there's absoultely no lip protection.
I just had a wheel replaced because the dealer curbed the car while I was there for an oil change. The curb was on a squared off speed bump..............still gotta be careful, regardless if it s 15 or not with the 8" width. high speed runs over those freeway bumps may still result in bent rims if they are light weight...believe me, I've done it and wasn't even driving agressively at all.
But if you like a lot of lip on a 15, then a low offset is in order. hope this helps
Old Feb 3, 2006 | 06:20 AM
phatcyclist's Avatar
205/55/15 is the correct upsize in terms of diameter for an xA/xB. Which means your spedometer will still be really close. As far as looks? You won't really notice the difference, it is 10mm in height for the diameter of the tire. I would say, go with the 205/55/15, just because it is the correct size.
Old Feb 3, 2006 | 06:27 AM
Burn0ut's Avatar
yikes...i'm getting the 15x8 bbist sportmax 0 offset rims...this means i have some thinking to do. thanks for the info...you got me scared now
Old Feb 3, 2006 | 01:32 PM
ctruss's Avatar
Get 195/55's They are aproximately the same overall diameter as the stock tires.
I have done stretched tires before and in my opinion 205's won't be stretched enough to look good.
Old Feb 3, 2006 | 03:11 PM
2tone_xB's Avatar
burn0ut - no matter what size, offset...you just gotta
watch out for any shiz on the road. i still drove with
caution with steelies. he's not trying to scare,
but he's just telling you the possiblities.
if you're careful already, good.
just be a lil more careful that you already are.
my rims have a slight stretch with
my lip sticking out the tire...boy do i drive 40mph all the time.
Old Feb 3, 2006 | 05:03 PM
Burn0ut's Avatar
yea i'm careful, but the little markers on freeways craziness...lol we'll see though. oh btw good luck with your sale, hopefully you can sell them and rock the rims i'm getting too
Old Feb 3, 2006 | 05:22 PM
fachiro1's Avatar
Also,
If you are going with those sm wheels, there's going to be some mods to the fenders that will most likely need to be done.
To me, the best looking would be the 185 or 195 50 stretched.
The 205 may not looked as stretched, but it is still ok.
a 55 or 60 will look more stock.
For the next set of tires, I'm going to go 195 50.
Old Apr 23, 2006 | 12:31 AM
Fujiz_xb's Avatar
sIcKsCiOnS
if i get the 15x8 imma do 205-50-15 . with toyo tires. i would do stretched but i travel to much.
also. if i add the -3 OTG camber will that work?
HotLavaDestiny
Apr 10, 2015 05:10 PM
dieselstation
Scion tC 1G Wheel & Tire
Aug 31, 2007 03:36 AM
reaubideux
May 29, 2007 06:05 PM
Boxer_Rebellion
Apr 22, 2007 03:03 AM
Alan
15
Aug 22, 2006 02:58 PM
