Would it be stupid to run camber shims...
Old Feb 6, 2006 | 10:40 PM
MikeC's Avatar
Default Would it be stupid to run camber shims...
...on 17X7" rims with a one inch lip, and a 42 offset? I want that VIP look, but can't afford to buy the NKB mesh rims in the classifieds.
Old Feb 7, 2006 | 12:28 AM
MikeC's Avatar
Anyone?
Old Feb 7, 2006 | 12:39 AM
Spider13's Avatar
You won't really get the same stance. You'd need the spacer and camber combo shims for sure. Also might need spacers on all 4 wheels to push them out enough. Even then it may look the same. Just mho.
Old Feb 7, 2006 | 12:46 AM
MikeC's Avatar
Thanks man, I gots no experience with this stuff, and would hate to waste the money if it's not gonna look right.
Old Feb 7, 2006 | 03:21 AM
magicmanjk808's Avatar
yeah, if you space it out and get them almost flush with the fenders it'll look mean. if, though, they are sunken in and you camber them, they may look bad and might rub the rear shocks.
Old Feb 7, 2006 | 04:32 AM
MattyRattyPoo's Avatar
Dont do it with those wheels. YOu need to get some low offset, big lip wheels to be cambering. YOu will just look dumb goen done the road.
Old Feb 7, 2006 | 12:54 PM
MikeC's Avatar
Thanks, I was'nt sure about that one. But I still need to figure out how to flush the wheels?
Old Feb 7, 2006 | 03:02 PM
superjeer's Avatar
IMO, 7" on 42 offset is too much to shim/space out. Do you have the wheels already?
Old Feb 7, 2006 | 04:14 PM
Boxer_Rebellion's Avatar
You would want an et25 or less to look good with camber IMO. You'd want a decent lip too, typical ricer rims won't cut it.
Old Feb 7, 2006 | 06:22 PM
MikeC's Avatar
Here's the rims, they are about all I could afford. I like them a lot, but would like a nice 4" lip.
Old Feb 7, 2006 | 06:33 PM
stankubrick's Avatar
If you're not rubbing, you don't need negative camber - unless it's for some kind of performance reasons.
If you want the VIP look, get at least 8" wide wheels or wider and at least +25 offset or lower. With these minimum specs, then you might need negative camber.
Additionally, stay away from sporty looking wheels if you want a VIP look.
Old Feb 7, 2006 | 06:48 PM
MikeC's Avatar
Understood, thanks.
Old Feb 7, 2006 | 10:13 PM
since its seven inches wide, you can make it a 0 offset in the rear. so that means is can be spaced out 42mm.... as for the front i would get a 25mm or maybe even a 30mm spacer.
Old Feb 13, 2006 | 02:44 AM
bBoxed_In's Avatar
you don't need a big lip to make the cambered look fly... you just need to learn how to do it right.
http://www.club-miniban.com/2004-11-08%200301.jpg
http://carview.r3h.net/images3.carvi.../168401/P1.jpg
http://www.club-miniban.com/2004-12-31b%200281.jpg
Old Feb 13, 2006 | 08:01 AM
bB2NER's Avatar
Music City Scions
Camber shims on a solid axle is a waist of money. It will look like the axle is bent. Keep the tires vertical. Rear shims to bring the wheels out to match the fronts are ok though. Check out www.onetongarage.com
Oh killer wheels Bro! Post up pics when mounted.
Old Feb 13, 2006 | 12:01 PM
MikeC's Avatar
I really like the look of those boxes man! :D Thanks bBoxdin.
Now It looks like the only way to get that stance is to run an air setup?
Old Feb 14, 2006 | 04:41 AM
cherryBox's Avatar
Is that safe? At all? Is that number divided across both sides?
(sorry, I really don't know)
Old Feb 14, 2006 | 01:40 PM
MikeC's Avatar
I don't know, and am trying to find out if the lug nut studs would be long enough after spacing out the wheel so much.
Old Feb 14, 2006 | 01:59 PM
SXT_HuntToKill's Avatar
DelMarVa
wrong about the axle thing... the rear axle flexes i go through tires int he rear more than i do in the front... i do a heavy cornering... and the rear wheel are already camber but not in the neg... its at +1.25... and you really don't need to camber unless it really performance wise... and if you do get it for looks and you want to save your tires get the nitto neo gen... no camber wear nittotire.com
Old Feb 14, 2006 | 03:01 PM
ctruss's Avatar
https://www.scionlife.com/forums/viewtopic.php?t=98189
Keep an eye on this thread if you want huge dish on a budget.
