View Poll Results: Do you rub at all?
Yes. Only when I turn hard.
9.09%
Yes. When I go over bumps.
27.27%
No. Not even when I turn hard of go over bumps.
63.64%
Voters: 11. You may not vote on this poll
215 45 17 Official Thread.Please Post 215/45/17 Tires!update
Old Feb 8, 2006 | 09:49 PM
active9x's Avatar
Default 215 45 17 Official Thread.Please Post 215/45/17 Tires!update
I was doing a search, at the moment I was looking to actually see how a 215 45 tire on a 17inch wheel would look like.
So if you have pics!! Show em off!
I want to see how porportionate the tire is to the rim.
So please post your pics and hopefully answer these 3 questions.
1. Width of the actual rim. (7.0",7.5",8.0",...) ?
2. Offset of the rim. (et40,et38,et35,...) ?
3. If your car is lowered..or stock... if lowered,how much? (1",1.5",1.7",2",or2"+)
I have been seeing a lot of threads about this one tire size. Yet a lot of them do not have pics. So this one thread will hopefully eliminate a lot of people's questions.
Thanks in Advance
Also I you can post threads of this topic to have a sort of data base of this topic.
Here are some topics I did a quick search.
https://www.scionlife.com/forums/vie...&highlight=215
Here are some links of members w/pic with this tire size.
https://www.scionlife.com/profile/jethro_b 17 x 7 - et40 - 1.5" Lowered
https://www.scionlife.com/profile/Stealpulse 17 X 7.5 -et35 - 1.6"F 1.5"R Lowered
https://www.scionlife.com/profile/stick_1NZ 17 x 7 - et42 - 2" Lowered
https://www.scionlife.com/profile/Lonely_Raven
http://www.sounddomain.com/ride/2052640 Added 2/9/06 17x7 - et42 - 1 3/8"F 1 5/8"R Lowered - No Rub.
https://www.scionlife.com/profile/Denstyr 17 x 7 - et40 - 1.06"F .91"R Lowered
https://www.scionlife.com/profile/Dwestxb Added 2/8/06 17x7.5 - et40 - 2" Lowered - No Rub.
https://www.scionlife.com/profile/CBSIMONSEZ 17 x 7.5 - et35 or et40 - 2" Lowered
https://www.scionlife.com/profile/Sid_xBicious Added 2/11/06 17x7 - et40 - 1.7"F, 1.5"R Lowered. 5mmF 10mm"R spacers.
Old Feb 9, 2006 | 12:46 AM
Dwestxb's Avatar
Wheels 7.5 wide, lowered 2"
Old Feb 9, 2006 | 03:10 AM
active9x's Avatar
Nice wheels.
Old Feb 9, 2006 | 07:26 AM
GLN305's Avatar
Motegi Racing RT5 17x7 +42 offset. Falken ZE512 tires in a 215/45-17. I'll see if I can get some better pics posted.
And here is where my wheel got messed up from the stupid salt here!
Old Feb 9, 2006 | 05:14 PM
active9x's Avatar
Thanks for all info guys! Keep em coming
PS: Salt can really damage wheels, ouch.
Old Feb 9, 2006 | 05:18 PM
GLN305's Avatar
Here's a pic of the wheels that I just got today with the same tire as above on them.
Old Feb 10, 2006 | 06:07 PM
Sid_xBicious's Avatar
Old Feb 12, 2006 | 04:48 PM
active9x's Avatar
Nice! Keep em coming!
Old Feb 12, 2006 | 10:35 PM
man, my wheels has ET40, but i did put 5mm spacer(front), and 10mm shim(back) both were OneTonGarage(van) items.
Also, springs were tien S-tech(1.7, 1.5).
Old Feb 14, 2006 | 12:31 AM
2006XB's Avatar
great thread!
i cant wait to get my 17's (winter is taking forever )
Old Feb 16, 2006 | 03:26 PM
scoobydo's Avatar
Default I agree, Great Thread!
OK, so their are many pics of the exact same setup I want to run,
only problem is that I have an XA not an XB.
I want to run 5Zigen FNO1R-C 17x7 +42 with 215/45/17
Stock, not lowered.
Is that setup possible with No spacers, No rubbing, and full front radius?
PLus, since this is what this thread is about, post pics of your XA if you have them.
Old Feb 16, 2006 | 10:09 PM
active9x's Avatar
I believe the xA and xB drive train and suspension are the same .
The green xB above is running that setup. He hasn't mentioned any thing about rubbing. I believe you will loose some turning radius considering its 2.3% bigger than stock.
Old Mar 20, 2006 | 07:35 PM
GLN305's Avatar
Old Mar 22, 2006 | 03:55 PM
RMS's Avatar
RMS
Question for everyone running 45's.
Do you feel much of a power loss with the slightly larger dia tire?
Old Mar 23, 2006 | 01:30 AM
Dwestxb's Avatar
I haven't seen a difference....
Old Mar 25, 2006 | 04:11 AM
2006XB's Avatar
just put mine on today. i had to trim a little plastic out of the wheel well. now weverything's fine. no rubbing. i have konig unknown's with BFG KDW2 215/45/17.
Old Mar 25, 2006 | 04:52 AM
Pitman's Avatar
17x7 sportmax -42 offset 10mm OTG rear Shims 5MM spacers all around.
Old Mar 25, 2006 | 12:58 PM
phatfront's Avatar
same tires on 17x8 et35 (& spacers on the back)
Old Mar 27, 2006 | 04:19 PM
Boxer_Rebellion's Avatar
17x7.5, et45 w/spacers&shims. Tein S-tech drop.
Old Mar 27, 2006 | 04:42 PM
2006XB's Avatar
finally got pics up.
in the first pic you can see where i had to trim away some plastic. you can also see where the tire rubbed and took the paint off. it's the same spot on both sides
