225's on stock wheels?
Old Feb 9, 2006 | 03:12 PM
dachmo's Avatar
Default 225's on stock wheels?
What are the widest tires that I can put on the stock wheels?
I want to get 225's, but I'm not sure if they fit properly. also, what size would they have to be? eg. 225/??/17.
Thanks,
- Dante
Old Feb 9, 2006 | 03:49 PM
DuMa's Avatar
225/45/17 will fit fine
Old Feb 9, 2006 | 03:50 PM
The_Instigator's Avatar
225 will fit the stock wheels just fine but you shouldnt go to anything much larger without going to a wider wheel.
Old Feb 9, 2006 | 03:57 PM
L4rry_B1rd's Avatar
I'm getting some Falken Ziex ZE-512 in 225/45/17. There great tires and only cost $92 a tire on discounttiredirect.com
Old Feb 9, 2006 | 06:32 PM
ack154's Avatar
Are there any downsides to running a wider tire? Or any benefits for that matter?
I was considering 225/45/17 for my new tires b/c they have those cheaper at tires.com than the 215/45/17 of the same tire on tirerack.com.
Old Feb 9, 2006 | 07:36 PM
L4rry_B1rd's Avatar
One of the benefits for me is the fact that the tire has a bigger sidewall. This makes the ride "more comfortable" because the added tire makes the bumps relatively softer. Im sure theres other benefits like more traction since more tire but im not sure about those.
Old Feb 9, 2006 | 07:45 PM
yesti's Avatar
pro: you get 'more rubber on the road'. con: more 'drag'. both of those may be minimal since we are only talking about 10 millimeters here (width) and 2.25 mm taller sidewall (4.5mm taller tire if i did the calculations right ;P). maybe better braking and at the limit handling but the last two differ based on tire brand/model if size is held constant.
Old Feb 9, 2006 | 07:56 PM
FModFTD's Avatar
Here is a good wheel/tire visual calculator:
http://www.rims-n-tires.com/rt_specs.jsp?postId=906
Just put the stock specs in the left hand side, and your modified one on the right, then scroll down to see the size difference.
Old Feb 10, 2006 | 02:04 PM
danman04x's Avatar
really good website
Old Feb 24, 2007 | 12:35 AM
vansterdam's Avatar
This tire calculator shows recommended rim width ranges for each tire size.
eric_m
52
Jan 17, 2019 05:50 AM
scionlife
371
Jun 2, 2015 11:00 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
yanges
Sep 30, 2003 02:31 AM
