Wheel locks for aftermarket wheels with tuner lugs?????
i have question. i just bought some new wheels for my tC. i live in iowa in the country, so the likelyhood that someone would steal my wheels is slim but, i love my new wheels and they make my tC look a lot better than stock and id hate to have them stolen. i do have "tuner lugs" the lugs that came with the wheels and they have a special key but there all the same. should i buy some acual wheel locks for my wheels for my own piece of mind or is it not necessary with the "tuner lugs"?
any opinions. any suggestions on where i can buy the locks/what brand i should get?
Originally Posted by tcholic
RAYS DURALUMINUM LOCK LUGS........
arent "tuner lugs" actual locks? or are all tuner lugs (of the same brand) interchangeable? for aftermarket wheels you just need a conical-seated lug, which has nothing to do with needing a special key. you can buy regular 22mm conical seated lugs for $1.50 each at most wheel shops.
Originally Posted by HKSpeed
arent "tuner lugs" actual locks? or are all tuner lugs (of the same brand) interchangeable? for aftermarket wheels, you just need a conical-seated lug, which has nothing to do with needing a special key. you can buy regular 22mm conical seated lugs for $1 each at most wheel shops.
i was just asking if folks thought that locks were necessary or if because tuner bolts were different that my wheels should be ok. thanks
These are nice locks. Because of the outer sleeve, thieves cant jam a socket over it or use pliers/vice grips to remove the lug....in theory.
Since the sleeve is free floating/rotating, I suppose if you get a larger socket that matches the diameter of the sleeve, you can hammer the sleeve off/down to expose the center/core of the lug. Then use another smaller socket and hammer it over the lug to remove.
http://www.gorilla-auto.com/products...=259&sfID2=261
kleecker
Scion xB 2nd-Gen Wheel & Tire
May 22, 2016 06:10 AM
scionlife
371
Jun 2, 2015 11:00 PM
