Help! 6-Disc Changer Problem!!!
Old May 8, 2004 | 12:26 AM
BlueScionXB's Avatar
Default Help! 6-Disc Changer Problem!!!
Problem...
I got the 6-Disc from a friend, and installed it in my xB correctly, but it isn't turning on...any suggestions...
Old May 8, 2004 | 12:29 AM
Huskersnow's Avatar
My first thought would be to check your fuses.
Old May 8, 2004 | 12:32 AM
Hmmm...where would the fuse be? The one in the engine compartment or the on in the steering wheel compartment...
Old May 8, 2004 | 12:38 AM
Huskersnow's Avatar
I personally have not looked for mine yet, but all of my past cars radio fuses were located under the dash inside the car, not under the hood. I could be wrong but I am sure someone here knows for sure.
Old May 8, 2004 | 01:05 AM
Okay, I checked all of the fuses and they are all fine...any other suggestions, maybe a fuse in the actual head unit HELP!!! I will die without my music...
Old May 8, 2004 | 02:57 AM
oneslowxa's Avatar
check to see if the antenna is plugged in or maybe even try hitting the power/source switch.
did you check all the fuses or just the one that said radio?
Old May 8, 2004 | 03:47 AM
DenZinz's Avatar
I assume that its the scion 6-disc right?
everything should plug right in if you are sticking the scion 6-disc into a scion. Try disconnecting and reconnecting it again, but yes check the fuses. Its located behind the pop out on the lowers left of the steering column.
Has any of the factory wires been tampered with? (i.e. cut, spliced)
Old May 8, 2004 | 01:39 PM
bryanb124's Avatar
did you read the sticker on the back of the changer...there is a locking mechanism for the changer that you have to do something with after you receive it from shipping...I just installed mine, but the seller didnt activate the shipping mechanism, so mine just worked fine when I plugged it in (thankfully)...
later
Old May 8, 2004 | 01:43 PM
KoonsAnnapolisScion's Avatar
DelMarVa
Scion Tuners
None of the units we have installed and I have done my fair share have had a shipping lock engaged.
RY_TC07
Jul 18, 2017 05:18 PM
ScionXa06
May 18, 2015 10:05 PM
BlueBox
14
Jan 15, 2004 01:08 PM
fearturtle44
Dec 14, 2003 06:57 PM
fearturtle44
Dec 11, 2003 04:37 PM
