Problems with my OEM fog lights [xB]
Old Feb 10, 2006 | 04:53 AM
BloodySunday's Avatar
Default Problems with my OEM fog lights [xB]
i have OEM fog lights on my xB and i installed luminics amber bulbs. they were fine for about a month. then one side went out. i thought that maybe luminics sells a crappy product. so i removed the wheel well plastic and attempted to take out the light. but as i did that, the fog light bulb magically worked. so it wasn't the bulb afterall [ to luminics for making a quality bulb, but for toyota for making a crappy harness]
it seems that if i wiggle around the harness the lights work. but everytime i think i fixed it, and put everything back together again, the vibration from me installing the wheel well plastic makes the bulb not work.
my question is, has anyone else had this problem? or am i the only one to receive a crappy fog light kit. if i'm not the only one, what was everyone's solution? should i just tape up the plug and bulb to prevent the wires from moving? i'm out of options and i'm kinda upset over it. thanks in advance for any help.
Old Feb 10, 2006 | 04:55 AM
Short_Bus's Avatar
Exact same thing happened to me. I kick my bumper and it comes back on. The harness is going bad, the bulbs take to much power for the harness to handle.
Old Feb 10, 2006 | 05:03 AM
so it's the bulbs that made it go bad? because it only happened after i bought the luminics.
Old Feb 10, 2006 | 06:41 PM
hayalex6's Avatar
I've had my Luminics yellow bulbs in my fogs for about 5 months, no problems here (knocks on wood)
Old Feb 10, 2006 | 08:38 PM
magicmanjk808's Avatar
what happens when you put oem bulbs back in?
Old Feb 10, 2006 | 09:01 PM
meemomark's Avatar
my problem, moisture builds up on the inside of the passenger fog....
anyone have that problem?
...sorry, im not trying to steal the thread.
Old Feb 10, 2006 | 09:19 PM
grizzly_choppers's Avatar
You have a cracked or unsealed fog light. You need to replace it.
As for the others, I second the question, does this happen with OEM bulbs? If so, take it in for warranty work.
Our club President, Roy, runs the JDM yellow Luminics bulbs both in his fogs and headlamps with no problems. He's had them in since late last summer. I don't think it's a widespread problem.
-Alex
Old Feb 10, 2006 | 09:21 PM
THE_DON's Avatar
I had luminics in my fogs for just over a month before one went out.
My other bulbs work fine in there. No problems. I blame the bulbs. Some people say they fry your harness.
Not dissing Luminics, but hey, I tried 'em, they died, I'm back to my old bulbs. No problems since. :shrug:
-THE DON
Old Feb 11, 2006 | 03:35 AM
pdrizzle's Avatar
DeepSouth Scions
Luminics bulbs do fry the harness. I had hyper whites in my fogs and they worked fine for a few months. One side stopped working. I bought JDM yellows, installed them, they worked right after I installed them, and now neither side works. I inspected the harness and the plastic had melted away from the metal connections. I'm going to buy heavier duty harnesses and wire in a relay to the battery. I'm not switching back to stock bulbs.
Old Feb 11, 2006 | 07:17 AM
larrdoggydog's Avatar
Does anyone have any detailed instructions on how to change the OEM Toyota factory fog lights bulbs? I have purchased some JDM Polarg Yellows. I know they will be cool and look very Japanese. I just can't figure how to get to the back of the lamp and pull the original bulbs out. ANY HELP ANYONE HAS WOULD BE GREATLY APPRECIATED.
Old Feb 12, 2006 | 03:36 AM
masafina's Avatar
BloodySunday Posted: Thu Feb 09, 2006 10:53 pm Post subject: Problems with my OEM fog lights [xB]
my men I have the same problem but is in the tC
I think is toyota is making crap conectors because my tC is 4000 miles old
and I replace the bulbs with hipper white and one goes... touch the cable and presto
they come back but I need to do that like 1,000,548,264 times a day
my friend have a Matrix with the same problem and in the shop I work
I fixed like 3 corollas with that problem so for me is the harness
Old Feb 12, 2006 | 04:11 AM
Buebie's Avatar
MN Scions
do i smell a recall?
Old Feb 12, 2006 | 07:44 PM
pdrizzle's Avatar
DeepSouth Scions
It's not a defect, if you use the stock bulbs they won't fry. It's an aftermarket bulb problem. The solution is a new, heavier duty harness that connects to the battery.
Old Feb 12, 2006 | 09:35 PM
exactly....
Old Feb 13, 2006 | 02:00 AM
masafina's Avatar
I take a look today to find wath the probl. with my tc headlights
and thats why I found :tap:
Old Feb 13, 2006 | 02:02 AM
pdrizzle's Avatar
DeepSouth Scions
That's the look of a fried harness. I have a couple of those too.
Old Feb 13, 2006 | 06:44 AM
you can just buy the pig tail or whatever it's called and a couple wires right? should be about 21 dollars or so. also, stick to stock bulbs or upgrade your harness...
Old Feb 13, 2006 | 01:10 PM
Dressed2Kill's Avatar
I had that same problem when i put nokya yellow bulbs in my fogs. I bought some new 9006 harnesses for my fog lights and wired them in.
Old Feb 13, 2006 | 03:39 PM
tmaikeo's Avatar
seriously i have that problem...sometimes the fog lights come on without ne light turned on...like the fog light by themselfs..and when u turn on my headlamps the fog lights turn off. but when u turn the switch off the fog lights my headlamps dont work...ish a little confusion in the wiring. ive also heard bout the wiring harness goin bad due to HID or a higher voltage in the bulbs
Old Feb 13, 2006 | 04:10 PM
and do you know where i can get this heavy duty harness? and will it be easy/simple to install? TIA
