Over-Revving
No, it will be fine! I used to do it regularly when I was learning how to race my nissan sentra, just don't make it a habbit lol! I believe the tc's redline is 6500 so you'll get there pretty quickly, I've learned to kind of time my shifts so that I don't over rev
yup. warranty just means toyota will do EVERYTHING in their power to prove it was your fault, if its a major issue. thats why im debating wheter its worth it getting the trd supercharger, for the same price as a turbo is worth it.
Originally Posted by Q_Z
yea my tc i redline it at 6500... but u no if ur tranny goes out itz all good rite..cuzz we still got warranty...
^^ There is a code for both over rev and over speed on most cars that I know of. So yes, they can tell if you have over revved. They should only deny warranty if it was determined that the over revving caused the issue. I am not sure, however if it logs the number of times it happened. If you drive around bouncing off the rev limiter all the time you a) need to learn how to drive and b) dont deserve warranty coverage anyway if it damages the car. But if it happens on accident once or twice just be honest if they ask you, cause they will find it out if they look for it.
why you laughing at what I said about warranty and how they will do everything in their power to prove it was your fault?
i think its true?
i think its true?
Also, that is wierd that it logs the number of times you bounce off the rev limiter. I thought the ECU only had something like a 15 second memory. That way, if you get in an accident, they can check how fast you were going, if the airbags went off, if brakes were applied, seatbelts on, etc. But after 15 seconds, it loops back and overwrites what is already there. I am not sure if it is correct, but that is how I understood they worked.
^^ I dont know if there is a counter involved. But there is a code for those limits, at least on some cars. The codes that are set will stay as long as power is applied. It is also just as possible that there is a section of memory that certain codes are stored in. Not sure if that is the case here, but the manufacturer would not say if it i was. A simple peice of Flash could be used for it.
My dad just had a car in recently he told me about actually. It was in for a different issue, but while scanning it he found a code he not come accross before. He looked it up: Engine Overspeed Limit Exceeded. Come to find out... her hubby also drove the car occassionally
But again, I dont know how that code is stored or how long it is kept. I doubt there is a counter to determine the number of times it is hit, but who knows really.
SpeedDeamon
Jun 30, 2007 04:23 PM
