Center Bore
Old Feb 15, 2006 | 03:14 PM
TheIcon's Avatar
Default Center Bore
Where can I find out the center bore measurements of my tire? Websites I look at don't seem to get that specific on the wheels? Any suggestions?
Old Feb 15, 2006 | 03:55 PM
stankubrick's Avatar
A ruler?
Old Feb 15, 2006 | 04:13 PM
TheIcon's Avatar
lol I thought that to but someone told me that it is a very detailed measurement like down to .01 or .001. Im trying to get hubcentric spacers made.
Old Feb 15, 2006 | 04:16 PM
DJ_X_Trodinaire's Avatar
look in the sticky wheel faq ;)
Bolt Pattern
4x100
Center Bore
54.1mm
Nut Size
M12x1.5
Old Feb 15, 2006 | 04:17 PM
FModFTD's Avatar
See the wheel fitment sticky post
https://www.scionlife.com/forums/viewtopic.php?t=348
its 54.1 mm
Old Feb 15, 2006 | 04:19 PM
If you aren't sure of your measurements, you can take your wheels to a tire shop, and they can measure for you. You can even test out some Hub Centric rings to be sure they fit....
Old Feb 15, 2006 | 04:35 PM
TheIcon's Avatar
That gives me some ideas. Thanks
Old Feb 15, 2006 | 04:37 PM
TheIcon's Avatar
its 54.1 mm
54.1mm is for stock. Im assuming its larger since i have aftermarket wheels.
Old Feb 17, 2006 | 01:44 PM
black_cube's Avatar
If you are getting the spacers made locally, just take a wheel to the machinist. Accurate measurement can only be made with a short vernier caliper.
But most wheel manufacturers list what the wheel is bored out to, what wheel is it?
Old Feb 17, 2006 | 04:51 PM
TheIcon's Avatar
Helo Diamond wheel. 18x7.5
Old Feb 23, 2006 | 11:52 AM
black_cube's Avatar
I couldn't find much info about those online. I emailed a company that sells those wheels and they replied with a 72.62mm cb. Either way, I would check the actual wheel before using that spec.
kb1sxv
Oct 21, 2015 05:00 PM
wayneside
Regional - Southeast
Sep 23, 2015 10:42 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
sccarally
Regional - Lonestar
Aug 21, 2015 02:58 AM
