o2 sensor
Old Feb 15, 2006 | 11:27 PM
cvicenti1's Avatar
Default o2 sensor
While installing my megan header, I ran into a problem..First off, the o2 sensor was a pain 2 remove and when I finally got it off..the screw was stripped! Good news is that the header is on and runs sweet..Bad news is that I riding around without an o2 sensor and a cel light is on. the Cel doesn't bother me but, just how important is the o2 sensor? Can I jus leave it off?
Old Feb 15, 2006 | 11:29 PM
Munch's Avatar
Default Re: o2 sensor
That is the Air fuel sensor, and yes you do need it. I wouldn't drive around to long without it if I were you.
Old Feb 15, 2006 | 11:43 PM
cvicenti1's Avatar
damn it...thanks 4 replying so quick Munch..where can I get a new one & how much is that gonna cost me? Out of curiosity, what will happen without it?
Old Feb 15, 2006 | 11:45 PM
Munch's Avatar
The car will not be able to adjust the air/fuel ratio. You can get a new one at any dealership, but it is costly.
Old Feb 16, 2006 | 12:00 AM
cvicenti1's Avatar
Thanks again Munch..yEa I just got off the phone with Servco and it's gonna be about $140 dollars..and they don't even have it in stock, they have 2 order it from the warehouse..thank god i'm on vacation..no driving around 4 me I guess
Old Feb 16, 2006 | 05:46 PM
Whocares05050's Avatar
yea, mine was struped as well from the factory. good luck
Old Feb 16, 2006 | 06:59 PM
metalranger33's Avatar
i drove without that o2 for a few months and no problems...then i fixed the o2 and my car runs the same
Old Feb 16, 2006 | 07:00 PM
fyi went the the track w.o o2 and pulled a 15.9 and went with the o2 3 months laters pulled a 15/7 so we all know that no engine damage happened
Old Feb 16, 2006 | 09:32 PM
cvicenti1's Avatar
That's good 2 know metal...I found this website called Parts Train & they have the o2 sensor replacement for like $30 without the connector, but that's shouldn't be a problem..I'll just use the original one..
Old Feb 17, 2006 | 02:07 AM
bbsciontc's Avatar
just a warning, that most likely will not work. Our first o2 sensor is a one-off wideband unit that meters differently from those universal sensors. As far as I know, you have to buy the oem one. One other thing that may work that hasn't been addressed is using an o2 sensor replacement for and 05-06 camry with the same engine. I found a replacement for that at rockauto I think for 80 something. But no one knows if that'll even work.
Old Feb 17, 2006 | 05:17 AM
cvicenti1's Avatar
crap
thanks 4 the warning...so if it doesn't work, u think I can splice the wire and use the new o2 sensor and the existing oem wires? damn.. if dats not da case then I wasted 30something dollars and 2days for the part.
Old Feb 17, 2006 | 03:13 PM
bbsciontc's Avatar
I'll be honest, I haven't tried it myself and hope I wont have to when I get around to doing the install. But others have had the same experience as you and found that only the factory one will work.
Old Feb 17, 2006 | 03:19 PM
just thought id mention this but i have read on this board and scionlife that a lot of people have had that stripping problem with the o2..so becareful when u go to the dealer thats a clear foul.
Old Feb 17, 2006 | 10:05 PM
cvicenti1's Avatar
I know metal said his car ran a high15 sumthing w/o the o2 sensor and a low 15 with the sensor, but technically...how do we know when the o2 sensor works when it is on???
Old Feb 17, 2006 | 10:28 PM
sportmaned's Avatar
why is there such a high possibility of this happening just from intstalling new headers?
Old Feb 18, 2006 | 12:59 AM
cvicenti1's Avatar
here is a tutorial for the o2 sensor replacement on a lexus:
http://www.lexls.com/tutorials/EFI/m...gensensor.html
I found it in one of the scionlife forums..since I already wasted $ on a universal sensor, I minus well try it
Old Feb 18, 2006 | 01:06 AM
peteyd's Avatar
well im using the aem uego wideband O2 guage.....it come with a bosch O2 senor on it... it cost about $295 shipped for me. On an Off note how importnat is the one on the spipe?? Im not running that one currently
Old Feb 18, 2006 | 01:27 AM
PolyFM_TC's Avatar
The one on the S-pipe is a comparison sensor. It is there to check to make sure that the catalytic converter is working properly. The reason people have to install anti-foulers is so that the sensor is pulled out of the exhaust stream and reads less contaminants in the exhaust. If the sensor is not there the engine will throw a "catalytic converter malfunction" error and your engine might go into safe mode after a while. While the 2nd O2 sensor does not control A/F ratio, (that is the job of the first one) it is very important to the emissions of your vehicle. Bottom line...put it back in!
Old Feb 18, 2006 | 10:40 AM
tikbhoy's Avatar
its there for a reason. i got mine for 275-280 otd. tracktimes doesnt prove that you can run without the sensor.
Old Feb 28, 2006 | 08:59 AM
Bsmntcuts's Avatar
Same thing happened to me. Bought one at the dealership for $230. It cost more than the damn headers. Check this out: https://www.scionlife.com/forums/vie...063&highlight=
