Best location for mounting tweeters
Old Feb 17, 2006 | 02:41 AM
SoCalMike's Avatar
Default Best location for mounting tweeters
Hey Guys.... I finally got my New speakers for my box... I went with Infinty Ref 6010CS. I had the 6000cs in my Xterra and loved them. What would be the best spot for them in the stock location on the dash or in the doors???? Any pictures would be great!!! Also do I need a mounting bracket for the rear speakers???? I am putting Infinity 5012si for rear fill
Old Feb 17, 2006 | 04:15 PM
trikkonceptz's Avatar
You always want to keep an elevated sound stage, so placing speakers in the dash locations would be better for your tweeters. Ideally though you would want to elevate them to just about eye level on the A pillars.
Old Feb 17, 2006 | 04:28 PM
GLN305's Avatar
I have mine the stock dash location and they sound GREAT! I highly recommend that. I also would recommend getting the tweeter as close to the factory grille as you can. I made an adapter out of 1/8" ABS and covered it in Dynamat. Works wonderfully.
Old Feb 17, 2006 | 07:33 PM
SoCalMike's Avatar
Hey GLN305.... Got Pic's?????
Old Feb 17, 2006 | 07:47 PM
GLN305's Avatar
I will in about 5 minutes...going outside to take some now!
Old Feb 17, 2006 | 07:57 PM
GLN305's Avatar
Here ya go:
Old Feb 17, 2006 | 08:05 PM
GLN305's Avatar
Oh, and for the rear speakers, you can use the front Scosche brackets and some self-tapping screws to hold them in. I did that with my Image Dynamics 6.5's. Unfortunately I forgot to get pictures of them.
Old Feb 17, 2006 | 08:23 PM
mavrichie's Avatar
I have my tweeters mounred in the front doors and the rear tweeters are mounted in the rear pillars.
[/img]
Sorry it is kinda hard to see because I painted the cover to match the door panel but they are at the top front of the door.
Old Feb 17, 2006 | 08:41 PM
GLN305's Avatar
I had mine mounted there, but it didn't sound too good, so I took the flush trim ring and covered it in grille cloth to fill that hole. That hole will be filled and covered this summer. I really like the sound of the dash locations
Old Feb 17, 2006 | 08:59 PM
mavrichie's Avatar
I have 3 way speakers in the front so the dash locations have my mids in them so the door was the logical location for the tweets. I think it is better to have the tweeters point towards eacch other for sound quality and the dash location for the tweeters does not allow for this.
Old Feb 17, 2006 | 10:15 PM
GLN305's Avatar
I was hoping for the same thing, but the door locations did not supply the best SQ. I had JL Audio 4" 2-ways in the dash and the component set in the door. It sounded good, but no where near as good as the current setup. My soundstage is twice as wide, the high end is much smoother, but maybe the different speakers we are using have very different off-axis responces.
Old Feb 17, 2006 | 11:07 PM
mavrichie's Avatar
You may be right as far as saying the different speakers may have different off-axis response and I have never had my tweets in a different location so I can't comment on how they would sound in the dash location. Did you sound deaden the doors when you had your tweets in the doors?
Old Feb 17, 2006 | 11:30 PM
ProshopXB's Avatar
I also ( like GLN305) have my Kicker 6.5 component tweeters in the factory 4 inch( im sorry 2.75 LoL) location on the dash. I made the same abs plates, but made mine just a bit bigger, so i could add a 2nd tweeter, if needed. And i get great sound from that location. Dont get me wrong there is always a better place to put them for sound quality, but i am trying to keep it as factory as possible, with no extra holes anywhere. Plus im deaf from to many years of installing car stereos any way, LoL
Old Feb 18, 2006 | 12:11 AM
FREQBOX's Avatar
I have one set in the kickpanels
and a second set in the a-pillars
Old Feb 18, 2006 | 01:16 AM
ProshopXB's Avatar
Sweet kicks, i like, best ive seen in awhile. Wish the color was just a little darker, but nice.
Old Feb 18, 2006 | 01:28 AM
FREQBOX's Avatar
thanks!..my buddy did a really nice job on the install...the vinyl actually looks alot closer to the corect color inperson...the flash reflects more off of the vinyl
Old Feb 18, 2006 | 02:52 AM
SoCalMike's Avatar
Some Sweet looking work here Thanks Guys!!!!!
Old Feb 18, 2006 | 12:45 PM
GLN305's Avatar
Yeah, I did deaden the door completely.
Old Feb 18, 2006 | 08:07 PM
FoDoToaster's Avatar
I had a little different approach with my "3-way" set. I did an Infinity Kappa Perfect woofer in the door, and a Memphis 4" coax in the dash. I cut the tweeter off the bass blocker on the coax and wired them all to a MB Quart 3 way crossover. The Memphis tweeter is a little harsh, but the fuller mid's sweeten the sound. I've also got a Phoenix Gold MS-275 powering them.
Old Feb 19, 2006 | 04:24 AM
superfreestyle's Avatar
DeepSouth Scions
problems solved
