Gauge question...
Old Feb 17, 2006 | 04:24 AM
peteyd's Avatar
Default Gauge question...
Ok....i have a noob question.....I just installed the aem uego wideband O2 sensor today...and not quite sure how to read it ........... =me but thats beside the point. any whos does green=good/yellow=okay/red=bad...or does green=lean/yellow=stoich/red=rich? Someone help a noob at first induction......when I idol im about mid 13s to high 14s and when i dirve it its around 10s to 12s. help please
Old Feb 17, 2006 | 01:30 PM
ScionDad's Avatar
Default Re: Gauge question...
Looks just a tad rich...but that's ok. Best power is usually obtained with an AFR of between 11.8 and 13.0 on most engines. The lowest average emissions are obtained with the AFR around 14.7 to 1 (stoichiometric) and best fuel economy is at AFRs between 16 and 18 to 1. Most engines do not idle happily unless they are setup to run richer than 14 to 1 AFR
To make it easy, green is good, yellow is ok, red is find out whats wrong FAST.
Old Feb 17, 2006 | 01:58 PM
Simplyscion's Avatar
Team No Limitz
good call on that one my man
Old Feb 17, 2006 | 03:13 PM
peteyd's Avatar
thank god i guessed right ()
When I was driving today it stayed mainly in green and went to yellow a few times but never red.....Ill floor it tonight and see what it does...when i did it last night it went to red and stopped working sooooo that wasnt good so ill try it one more time if it isnt raining tonight.
Old Feb 17, 2006 | 07:34 PM
ZPIracing's Avatar
On a stage 0 at WOT you should see AFR in the high 10's low 11's. On the highway in off boost driving you want to be in the 14-15 raneg as this will keep gas mileage well.
At idle it really does not matter as there is minimal load on the engine. The two you really need to pay attention to is WOT and part throttle boost driving.
-ZPIracing
Old Feb 18, 2006 | 01:01 AM
peteyd's Avatar
-ZPIracing
if im pushing the car it goes to 14-15....during normal driving im getting about 12s or so if i really push the car the guage seems to go off soo guess im running to rich or too lean....(----) is what the guage lookes like when im pushing the car and after i do that if i let up off the gas and just coast or apply the break it looks like that so not quite sure what that means.
Old Mar 3, 2006 | 03:02 AM
ERIC-TC's Avatar
Did you ever figure out what was happening? I'm currious as to what the ECU is doing at WOT. Can the injectors and fuel pump keep up?
Old Mar 3, 2006 | 06:10 AM
TCpete's Avatar
bump because this is starting to be a good thread for info on AFR;s on our tc's on boost
SloTC1
Aug 16, 2018 02:45 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
paisatronix
Sep 5, 2015 04:13 AM
