Lower RPM
Old Feb 18, 2006 | 01:29 AM
whatmovesu's Avatar
Default Lower RPM
Is there anyway to lower the rpm on my xA 4K at 80 is scary.
I know I could let off the gas and change the transmission but is their anything else??
Old Feb 18, 2006 | 01:55 AM
jct's Avatar
jct
change your gear ratio, other then that i just go use too it engine handles just fine at that spd
Old Feb 18, 2006 | 02:01 AM
x_rayted711's Avatar
Larger diameter tires will change the RPM, but it affects the accuracy of the speedo, puts more wear and tear on the motor and drivetrain and also wheel/tire clearance could be affected.
Old Feb 18, 2006 | 02:51 AM
dexter_5000's Avatar
only if improperly sized. the correct offset and tire wheel combo will not affect the speedo that much.
Old Feb 18, 2006 | 04:14 AM
^^^I understand that, but if someone were to drastically change the tire diameter to lower the RPM at 80, it would affect the speeo more. If you go with a HUGE tire, it will lower the RPM....but there are negative affects.
Fisqual
Sep 22, 2015 05:51 AM
hampton1100
May 28, 2015 07:32 AM
Bobb_Todd
Jan 16, 2015 06:57 PM
cid_mcdp
Jan 5, 2015 02:45 PM
stankubrick
21
Jan 4, 2004 06:30 PM
