HELP!!!anyone with s7 autotechnic guages
Old May 12, 2004 | 04:20 AM
ONE_HOT_BOX's Avatar
Default HELP!!!anyone with s7 autotechnic guages
i got mine 2day and im tryin to put them in and the instrucs really suck, it came with some white circle stickers and i dont know where to put them....can u help???
Old May 12, 2004 | 04:30 AM
windowtint's Avatar
from the picture - I don't see any white circles in the set up.
are you sure they just aren't extraneous peices and not meant to be installed?
Old May 12, 2004 | 04:35 AM
i cant c where they would go, just wondered...they prolly dont belong in the kit
Old May 12, 2004 | 04:41 AM
showpaojoe's Avatar
IV ACE
haha...i got the whole line up of 7 S7 gauges but haven't even looked at em yet. hope it's not as bad as you make it seem
Old May 12, 2004 | 04:47 AM
thyere pretty self explanatory...but the instructions kinda say "figure it out urself" and the pics are for some other car, just thought it would be better....
Old May 12, 2004 | 05:03 AM
p.s. if anyone has them installed...where did u get power from?
Old May 12, 2004 | 05:15 AM
EVILDAVE's Avatar
Mine did'nt come with any stickers and I tapped into the yellow wire in the big plug that is hooked up to the A/C controls that is the dash light.
Old May 12, 2004 | 05:38 AM
Minsk99's Avatar
I have the Ac D5 series gauges which I think are a little different, but I hear you on the AC directions being lacking to say the least.
Anyway, I had two power hookups for mine. The first was a red wire that was for operating power and that I taped into the back of the lighter beneath the ash tray. I used one of those quick splice plastic things for 18 to 20 gauge wires (can get a Radio Shack or any car parts store).
I also had a yellow power wire that was to turn on the lights of the gauges. You could splice these into the same lighter wire, but I think it's a cleaner install if you make them illuminate only when the headlights are on. I spliced into the solid green wire that illuminates the lights behind the climate controls. If you take your center dash panel off there will be three wire clusters that need to be disconnected from the back of it. The largest of these (it is white plastic) snaps into a center white plastic rectangular piece which is about 3.5" x 2.5". The solid green wire that is part of this cluster will provide 12v only when the headlights are on.
You should also have a black grounding wire, I grounded mine at a factory ground point that is located right below the interior fuse box (lower left corner by your left foot if you are sitting in the car). You will need to remove the plastic panel that simply snaps out. You will see several white and black striped wires that are already grounded there.
I don't know how much wire length you were given with the 7 series gauges, but I had to extend my gauge wires with 22 gauge wire so they would reach the points we are talking about. I used a soldering iron and shrink tubing, but I'm sure that one of those crimped on connection cones would be just fine and much easier.
Keep in mind this install was for the AC D5 series, but I'm assuming that it will not be too muck different form yours.
Old May 12, 2004 | 09:07 PM
thanks for the help guys...i can always poke around in there with a meter and find the wire i need for power, just wanted to see if anyone had done it yet, so i would know where to start looking and maybe save some time. ill snag that yellow wire and splice into that.
thx again
Old May 14, 2004 | 04:07 AM
Piston's Avatar
I cant remember the wire exactly, but I beleive it is green with a silver band, on the gauge cluster harness. I would test it to be sure, but once you ture the lights on it work perfect.
I had to modify the tach portion to get it to fit right, but other then that the gauges look great. I also have the S7 volt gauge, but I am testing to see if I want to keep it before modifing the dash.
Jason
Old May 14, 2004 | 07:13 AM
mikochu's Avatar
Is it hard to see the needle? Also... Anyone install this in an xA? Pics? Thoughts?
I think it'd be harder to see where the needle is...
Old May 14, 2004 | 07:14 AM
Piston's Avatar
Actually it is not that hard to see. it took me about 10 minutes to get use to.
Jason
Old May 14, 2004 | 05:36 PM
XBman's Avatar
that set up looks pretty cool
Old May 14, 2004 | 11:03 PM
showpaojoe's Avatar
IV ACE
pictures make the needle look deceiving. in actuallity, it is is easy to read at night
Old May 16, 2004 | 06:15 AM
got em in today... thanks for the help, i ended up tapping into my radio harness dimmer wire for power.
the needle is easy to see, especially at night, if anything theyre harder to see in the daytime.
Old May 16, 2004 | 06:56 AM
mikochu's Avatar
There are factors that are preventing me from buying the gauges... Changing my stock HU and odometer led colors... the S7 gauges just add more weird colors to my interioir. Don't get me wrong, I love the color scheme, but it doesn't match the rest of my interior...
elwaylite
9
May 15, 2020 07:27 PM
2014AbsolutelyRed
Scion tC 2G Aero & Exterior
Jul 31, 2015 05:09 AM
Captain_Scion
Mar 27, 2005 06:40 AM
1111
31
Oct 19, 2004 04:11 AM
BrockAbabba
Sep 30, 2004 02:14 PM
