Fuel tank, first half go further than the second half?
I have to admit I have never done my own research but I could swear the first half tank of fuel goes further than the second. Has anyone researched this (other than my uncles friend says…)?
Thanks in advance!
Thanks in advance!
It's been my experience that in most vehicles that when you fill them up, full doesn't accurate reflect the additional fuel that is in the fuel filler pipe. Also, on a lot of vehicles they put the "Empty" mark above the actual empty line for those of us that like to ride the tank all the way to the empty mark and beyond. Because of this it appears that you get way more milage on the first half of the tank than the second. xBs may not be the same, but that would be my best guess that they are.
Music City Scions
Yes, they indeed design them like that. It makes you think you are getting better MPG than you are. Just don't try to fill it more than a few cents after it clicks and your charcoal filter and wallet will thank you. Also check MPG's over 3 tankfulls instead of every one. You'll get a more accurate reading.
no its not the fuel in the line or anything of the sort its the way the sender is designed and is in all cars as far as i kow
http://auto.howstuffworks.com/fuel-gauge2.htm
be sure to click play on the flash animation
http://auto.howstuffworks.com/fuel-gauge1.htm
Please people, if you don't know the right answer don't pretend, just research it yourself or move on. There's no reason to spread misinformation all over the place because you want to believe some hyped up theory.
Music City Scions
Wow, so why didn't the automakers correct the design flaw so the guage would match the tank when it is half -full??? Because they didn't want to. They like people to think they get to go farther for less. It makes them feel better about their vehicle.
It isn't a theory. It's a fact. At least it's been this way with all of my 50 plus cars I've owned over the years.
They don't correct the "design flaw" because nobody is so delusional to think that a gas gauge that lingers on full for awhile is a full blown mind control device thought up after years of research in conjuction with the oil companies while throwing kickbacks at the EPA to keep this bastardly equipment under wraps. They don't correct the "design flaw" because a device that is accurate to the milliliter to the driver is totally worthless to 100% of new cars sold to the general public and probably costs 10x as much and is 10x as complicated to repair.
This is like asking why the automakers don't correct that silly design flaw where speedometers don't register under 10mph. You know, they do that so people with automatics don't think they are moving when the car is in gear and they let their foot off the brake. After all the gauge still says 0! The automakers are just trying to keep us in the dark because we can't possibly come to any rational conclusions ourselves. =\
On the last tank I got 20 miles less on the last half than I did on the first half.
I will continue to clock the mileage between the first half and the last half and see if I can make the spread a little more accurate
Atticus_the_XB
Apr 13, 2015 06:46 PM
