Can we swap heads??
Old Feb 23, 2006 | 07:02 PM
t_urbo_C_harged's Avatar
Default Can we swap heads??
I was wondering if anyone knew if it was possible to put the 1az-fe head on the 2az-fe block? The 1az-fe head is much more efficient with its direct injection. It also flows a lot better from what I am told. I know that these motors are basically the same, just different rod:stroke ratio and other stuff like that. Do you think this can be done? I just think it would make for a lot better/reliable motor... I mean other motors and heads have been mated like this before, I.E. B16 head on ls, etc. etc. I posted this a while back on clubsciontc but didn't get any answers so I was just wondering if anyone has attempted it or know if its even possible... thanks
Stephen
Old Feb 23, 2006 | 09:23 PM
aarontrini85's Avatar
Default Re: Can we swap heads??
Stephen
toyota doesnt usealy swap that east
case in point the 2jz-gte and the 2jz-ge heads are not interchangable
try it out though and let me know how it goes ill be 2nd in line (right behind you) for a head swap if you can pull it off
Old Feb 23, 2006 | 11:47 PM
garyc_01's Avatar
y would u want to go from a 2.4 to a 2.0?
Old Feb 24, 2006 | 12:03 AM
The_Instigator's Avatar
Its not a motor swap...just a head swap. Overall displacement wont change.
Old Feb 24, 2006 | 12:11 AM
garyc_01's Avatar
its a 2.0 motor im pretty sure thats what a 1az is and 2az is 2.4 and the only head that i know you could swap is a 88-89 3sgte with a 90-93 3sgte alltrac but u must use exhaust, intake man. and alot more to it
Old Feb 24, 2006 | 02:47 AM
like The_Instigator said, it is a head swap, not an engine swap. These motors are pretty much identical except the rod-to-stroke ratio and the head. The rod-to-stroke ratio is basically what determines how high the engine revs, how much torque the motor will produce, and the "liters" of the car. The head is a direct injection head, called by toyota the D4, and this head flows a lot better then the current 2az-fe head (I have heard and read). The reason I would want to do this swap would be to have a lot more control of the fuel because it would be much more efficient with the direct injection, and thats where the better flow helps too. I know it may be impossible, but there is always a chance. Maybe this combo would produce 200+ hp with a good tune, CAI, exhaust (the basics) or maybe it wont work at all. I just thought it would be an interesting topic to discuss and see if it could actually work and produce good numbers. Maybe ZPI could loan me a stage 1 racing block so I could test fit it!
Stephen
Old Feb 24, 2006 | 03:33 AM
hahaitzskippy's Avatar
all though the engien parts are similar or identical as some of you stated, it will not work beacuse the toyota parts are not UNIVERSAL as the honda B-series or K-series engines,
i've looked into this alreayd and i have already contacted toyota engineers, they said it wunt work.
prove me wrong someone because LIFT iwould be an awesome feature in our engines... but then again, we cant rev high enough for LIFT so its kinda pointless.
Old Feb 24, 2006 | 03:40 AM
Scionara_tC's Avatar
anything is possible with the right machine shop
Old Feb 24, 2006 | 03:43 AM
Stephen
first off he wasnt saying it was a motor swap he said he knows you could swap on the old celica
and as far as the size of the 1azfe every thing online says its a 2.0l motor
http://www.enginereplacement.com/htdocs/toyota.htm
http://www.overlander.com.au/pg/vehi...sts.php?id=219
and ill stop here since this is straight from toyota lol
http://toyota-africa.com/showroom/av...003/specs.html
I WIN!!!
Old Feb 24, 2006 | 03:57 AM
kcautotc's Avatar
hey man i live like 20 min away from you!
nothing great just dont see to many people on here from around where we live. turboed, eh? you oughta swing that whip by and let me take a test drive
btw, wtf is up with the weather???
50's two weeks ago,
teens last week,
back up to 50's again! I went from wearing every winter excessory i had last fri night when it was like negative degrees and now i barely need a jacket! weird. i guess that mo for ya! Later
Old Feb 24, 2006 | 04:51 AM
[quote}first off he wasnt saying it was a motor swap he said he knows you could swap on the old celica
I WIN!!! [/quote]
I could have swarn I read that they are the same block, just different bore, stroke, and rod legth... I couldnt find it right now though, its too darn late!!! I will try and find it tomorrow though but I could be wrong! I have been wrong before, although rare! j/k well you stumped me as of now, and I will admit you win for now...
Stephen
Old Feb 24, 2006 | 07:01 AM
same block doesnt mean same displacement
in fact. different bore and stroke usually means different displacment.
the bottom end on the 1azfe might be different as well.
Old Feb 24, 2006 | 12:41 PM
it is diffrant did you see my post just above yours???
Old Feb 24, 2006 | 02:37 PM
they do have different displacement...
1az-f(s)e = 2.0L = 1998cc
2az-fe = 2.4L = 2362cc
I again could have swarn I read that these engines are basically the same, but I am guessing I was on drugs that day j/p
Stephen
Old Feb 24, 2006 | 02:48 PM
Stephen
if the head fits though it could be like doing the b16 head on the b20's that makes a monster so check to see if it fits
it still might be worth it
Old Feb 28, 2006 | 02:06 PM
well first I need some specs of each head first to see if the 1az-fe head is even big enough for the 2az-fe block, let alone seeing if its compatable...
Stephen
MadTitan
Jun 16, 2016 06:23 PM
Bish80
Jul 24, 2015 02:02 AM
Jumphiggggg
Scion tC 1G ICE & Interior
Jul 15, 2015 02:29 AM
StxArOne
Jul 13, 2015 06:25 PM
dixonge
Jul 11, 2015 09:27 PM
