Power Distribution Question
Old May 13, 2004 | 03:29 PM
ikhonlord's Avatar
Default Power Distribution Question
I will be installing in my car the following item:
- Amp
- 7' LCD
- Carputer
My questions is:
If I get this "Power Distribution" box
Here is the link for more details:
http://www.crutchfield.com/S-pQwvFnc...nfo&i=211DB448
Will I be able to connect the three items above and have no problem?
Also, I know I have to use "in line" fuses in between the accesory and the power box therefore my question is....should I try to get the same capicity fuse that for example my amp has? or should I get a stronger fuse just in case?? As far as the fuses for the 7' LCD and the carputer, what size should I use???
Thank you very much for your help!
Omar
Old May 13, 2004 | 06:00 PM
DJ_X_Trodinaire's Avatar
you can also get one with fuses built in
as for the lcd fuse best way is to see what is written in the manual
i like this one
Old May 13, 2004 | 10:43 PM
one80ikyu's Avatar
Check out this one,
I use it in my car, It has a single 4 guage "in" on the right" and three 8 guage "outs" on the left with a sperate fuse for each.
Not sure on the price, I got it for free from my local stereo shop buddies, they take care of me pretty well. It is probably about 25.00 dollars or so.
It should work fine for your application.
Old May 14, 2004 | 02:56 AM
ikhonlord's Avatar
Thanks guys!
How bout the Amp question?? Should I get an "inline Fuse" the same as the amp or should I go highes just in case??
Thanks!
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
ScionLife Editor
Feb 25, 2015 04:40 PM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
