Need help with audio problem
For some reason my subs everyonce in awhile will drop in volume then bounce back up with in 5-10 seconds. I double checked all the wiring and everything is connected tight. If anyone has any insight on this I would appreciate it.
Thank you,
Kenneth Devorak
Thank you,
Kenneth Devorak
Are they dual voice coil subs? there could be a change in the Impedance. Try hooking up one sub at a time and see if it only happens to one and not the other it it happens with both then it is not the subs. Also make sure that the amp is rated for the load you are running into it meaning 2 ohm or 4 ohm
Beesh
Jan 9, 2015 06:30 PM
