tein s techs...bump stop
Old Feb 25, 2006 | 02:20 PM
deofaz's Avatar
Default tein s techs...bump stop
was just wondering if it really critical that you cut the bumb stop on a scion tc when installing new springs (in this case, tein s techs).? It is the little rubber part at the top of the shock/strut. Me and my dad put them on and then noticed the little instructions in the box saying that you need to cut the bump stop. I hope this makes sense and if any of you know anything about it let me know. I did search for it, but didnt find much. Thanks guys
Old Feb 25, 2006 | 03:41 PM
deofaz's Avatar
any help
Old Feb 25, 2006 | 04:26 PM
deofaz's Avatar
i dont know if this is a noob question....but i just want to know if i have to tear everything apart again to shorten them
Old Feb 25, 2006 | 05:21 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
when i had my TRD shocks and TEIN springs, i cut the bump stop slightly
Old Feb 25, 2006 | 05:22 PM
Shoe_Here's Avatar
i cut mine when i installed my TRD springs. i would cut them
Old Feb 25, 2006 | 05:27 PM
deofaz's Avatar
what difference does it really make?...
Old Feb 25, 2006 | 09:43 PM
Stock's Avatar
ride quality i believe
Old Feb 26, 2006 | 01:19 AM
Gortok's Avatar
The limit of shock/strut travel is cushioned with the foamy rubber "bump stop" to minimize damage to the car and possible loss of control.
Because, the car is lowered, cutting the stop keeps the car from hitting it too easily since there's less travel.
Since most lowering springs are stiffer than stock, there's less chance of hitting them, but it's a good idea to trim them to insure no unwanted bump steer...
Hopefully, this makes sense...
Old Feb 26, 2006 | 04:54 AM
Cheeky's Avatar
Cut mine in half when I installed my Tein H-Tech's
Before we cut..
Old Feb 26, 2006 | 01:24 PM
Gortok's Avatar
The instructions on mine said to cut approx. 25mm
This is about 1 inch so I cut the first lump off mine...
Old Feb 26, 2006 | 02:27 PM
Stock's Avatar
question though if you didnt cut them as much as it said would you keep your struts longer since they are not going down as far?
Old Feb 26, 2006 | 02:38 PM
Gortok's Avatar
It's not the "going down" part that's bad.
Most lowering springs have a stiffer spring rate. That means it's gonna have a shorter travel than stock. Usually, this will cause the seal to run warmer and wear on a shorter portion of the shaft.
Someone recently posted a picture of a worn strut with a discolored shaft due to heating. This is how it "blew out"...
I recommend a spring with a "close to stock" spring rate. The Tein H-tech and the Tanabe NF are the best, in my opinion.
This is, of course, for a "daily driver". If you plan on competing...coil-overs are the best way to go.
Old Feb 26, 2006 | 02:50 PM
Gortok's Avatar
The reason you cut the stop is to avoid a premature bottoming out on a larger than normal bump/dip.
It's pretty hard to control a car that's riding on the bump stops.
Old Mar 1, 2006 | 06:54 AM
akosij3lpot's Avatar
Default I didn't cutt mine
Concerning cutting the rubber thingy, I installed my Tein S, well my friends did it and the reason it wasn't cutt because they said I dont need to, so is there something bad with not cutting the rubber thingy?
Old Mar 1, 2006 | 11:07 PM
deofaz's Avatar
i dont think it makes a huge difference....from what i have gathered. I just put s techs on mine too. Its an awesome drop! later
Old Mar 6, 2006 | 04:37 AM
chrischoi's Avatar
cut or not cut.. lol
Old Mar 6, 2006 | 01:01 PM
Cheeky's Avatar
Listen to what he says....
Old Mar 6, 2006 | 04:57 PM
-NEMESIS-'s Avatar
Here is the simple reason for cutting the bump stops. When you put drop springs in the car you take away some of the shock travel (s techs= 2" drop something like 13/4'' shock travel lost ) i think that is the measument. To gain some of that travel back you cut the bump stop. You will notice in the tein factory instructions for H's you cut less, 1.5" H's drop as opposed to a 2" S's drop. The cutting ensure's that you have a nice smooth ride even on a harsh bump. instead of the suspension compressing and hitting that bump stop on every little bump you drive over because of the reduced shock travel, giving you that bouncy ride that nobody wants, and possibly creating a dangerous driving condition.
Old Mar 6, 2006 | 10:26 PM
dz_nutz's Avatar
Don't cut them... i don't have a problem with them and tucson doesn't have great roads... the ride quality is still the same from stock....... Have fun with whateva you decide....................................................................................................
KSwag
Jan 24, 2016 07:52 AM
jnesselroad
Sep 15, 2015 06:57 AM
BlingSlade
Sep 5, 2015 08:52 AM
Itgb
Sep 2, 2015 05:18 AM
