Suspension weird after wheel rotation?
Old Feb 26, 2006 | 06:38 PM
dachmo's Avatar
Default Suspension weird after wheel rotation?
I rotated my wheels the other day and after the wheels were back on the car and torqued to 76lb ft as per the manual, the suspension felt extremely bouncy. I would go over bumps and the car would just about come off the ground.
I Jacked the car back up and reinstalled the wheels and it was ok.
a couple days later I installed new wheels. same problem. and same fix.
could it be that the suspension needed to settle back??? It was pretty cold out 35-40 but I dont think that would have done anything.
I have the TRD shocks and springs.
Any thoughts?
Thanks,
- Dante
Old Feb 27, 2006 | 06:48 AM
hahaitzskippy's Avatar
suspension being stretched then it needs to settle
and most of its in your mind
imo
Old Nov 10, 2006 | 03:46 AM
hunterUnknown's Avatar
i have the exact same problem right now, except my wheels have not been removed. all i had was my tranny flushed so my car was up in the air.
the car realyl does lose traction at the drop of a hat.
Old Nov 10, 2006 | 02:10 PM
krdshrk's Avatar
Check your tire pressure - if you rotated the tires, make sure the fronts and rears are set to the correct pressure.
Old Nov 10, 2006 | 06:15 PM
oh i did. i deflated them, and it made no real difference. but i think its just the fact that the suspension got unsettled. because its been 2 days now, and magically its working again. and now i recall when i installed them, i was like wtf is wrong with this. its so crappy. and then i forgot about it. and now i realize, because it settled.
so what im gonna do today, is put the car on jackstands and compress the suspension one wheel at a time with my jack, and leave it compressed for a minute, and see what happens once i do it to all wheels.
hopefully this'll end settlement issues.
Old Nov 10, 2006 | 06:31 PM
Baron1C's Avatar
good to know wbout the TRD supspension setup.
Old Nov 10, 2006 | 08:12 PM
NoLimitzBuilt's Avatar
Team No Limitz
So how are you going to keep the suspension compressed and set the car back down? Just drive it for a couple days and let the springs resettle back in there. Just sounds like your springs shifted alittle while in the air. Not a big issue at all.
Old Nov 11, 2006 | 01:05 AM
well it didnt work anyway... but i set the front of the car on jackstands and used the jack on the front wheel for a bit, and then dropped it. but i didnt want to do it that long, as the pressure in the tire was a bit low, and i could see it bulging quite a bit. :[
to be honest it has to have something to do with cold weather. i really dont know, but im thinking that.
evolving_machine
Oct 21, 2023 01:16 PM
ScionLife Editor
Nov 20, 2014 05:20 PM
ScionVan
11
Dec 2, 2003 09:37 PM
