ugly chrome ring at the top of shift boot.
Old May 16, 2004 | 03:32 AM
hnefrdo's Avatar
Default ugly chrome ring at the top of shift boot.
i swapped out my stock **** for a TRD ball type **** recently. the feel of it is great, but having the ball **** exposes the ugly inside of the chrome ring.. does anyone have a fix for this? how to i rid of the whole chrome part completely?
please reply.
thanks.
Old May 16, 2004 | 03:58 AM
mikochu's Avatar
My friend has that shift **** on his celica, and his shift rod started to rust. If I end up with what I call "the gonad shift ****," I'll probably put heatshrink tubing, heat it up, then keep it like that..*shrug* sounds like a good idea... You can also get a new shift boot...
Old May 16, 2004 | 04:21 AM
BraveLittleToaster's Avatar
Havent done it so I dont know but you could throw some bondo in those grooves shape it and crome it with a can (krylon).
Old May 16, 2004 | 04:49 AM
bBted's Avatar
Default Re: ugly chrome ring at the top of shift boot.
please reply.
thanks.
u need to take out the shift boot...and take that ring out from bottom...
Old May 16, 2004 | 06:14 AM
mikochu's Avatar
If you take the boot and base ring (both one piece) off, you hear outside noise louder...
ohh...the ring on the shift rod? so he can tuck the boot lower?
Old May 16, 2004 | 04:55 PM
Guest
Guest
Posts: n/a
the chrome piece under the shift **** looks better if you flip it upside down. The bottom portion of the chrome piece looks better.
Old May 16, 2004 | 05:20 PM
mikochu's Avatar
Chrome piece upside down? hrmmm...
Old May 17, 2004 | 12:46 AM
Netobox's Avatar
Default Reversing chrome piece under the shift ****.
Yes, replacing the stock shift **** can leave you with a wide and rather odd looking chrome piece right below the replacement ****. I remember several people at Exposed who had changed their ***** in their xb's but had not reversed the chrome piece.
When I was there, I remember I told a couple of people how to reverse it. I didn't like the way the nice new **** looked with the wide chrome piece. This is what I did:
1. Remove the **** from the stickshift.
2. pry off the bottom of the boot from the center console
(be careful, it is easy to break the clips that hold the boot to the console).
3. Take the boot off the stick shift.
4. Turn the boot inside out.
5. On the inside, the chrome piece is held by a wire fastener, take the fastener off.
6. Take the chrome piece off and reverse it.
7. Follow the reverse steps to put the wire fastener and boot back on where they belong.
I found that reversing the chrome piece works if you have a stock shifter.
It would not go into the TRD short shifter that I got later. Eventually I returned the TRD shifter after I found it defective.
Anyways, I put the reversed chrome piece again on the stock shifter.
if you reverse it you will find that the other side of the chrome piece is tapered and makes a better match with your new shift ****.
Old May 17, 2004 | 11:22 PM
hnefrdo's Avatar
wow. thanks for the replies. they are very helpful!
YooItsJay
Dec 2, 2015 08:13 AM
danielv
Aug 26, 2015 07:14 PM
archangel
Apr 12, 2015 01:33 AM
AMLorick
Jan 25, 2015 12:14 PM
minter66
Dec 15, 2014 01:45 PM
