fidanza flywheel squeeking?????
Old Mar 5, 2006 | 01:59 AM
SXT_HuntToKill's Avatar
DelMarVa
Default fidanza flywheel squeeking?????
i had the fidanza flywheel installed about 2 weeks ago and i noticed at low rpm at low speed or just sittin still and tapping the gas a bit i get a squeek or chirp from the motor almost like a spark nock??? anyone know or have this same problem i use shell gas it is the best i have where i live...
Old Mar 5, 2006 | 01:40 PM
DelMarVa
allright thanks for the input....
Old Mar 5, 2006 | 06:29 PM
frogbox's Avatar
Squeaking like an engine knock?
Uhmmm....
You have them lube the pilot?
Replace the throw-out bearing?
Belt have enough tention?
throw-out bearings squeak and squeel if out or on their way out, usually replaced with any clutch work to save from doing a tear down again.
belts adjusted?, they probably removed them during the flywheel install
Old Mar 6, 2006 | 01:59 AM
DelMarVa
not a belt squeek noise its a chirp like a bird chirp but only under 2k rpm when it gets higher it stop... the car runs fine... im thinkin it might be injectors... not throw out that is replaced everything was done correct... i heard that if a flywheel was out of balance it will chirp or squeek... wouldn't understand why... never heard it till i got the wheel installed.... so im not sure if the out of balance thing is true or not...
Old Mar 6, 2006 | 02:32 AM
frogbox's Avatar
Still sounds like the throw out, maybe it is just adjusted to tight.
Never heard a flywheel squeak because of imbalance, warped maybe, but not imbalance.
Could be that the throw out was defective since you installed a new one.
Old Mar 6, 2006 | 07:50 AM
hotbox05's Avatar
thats just sooo light. i'd hate having to rev match in traffic everyday.
Old Mar 6, 2006 | 02:18 PM
trdsparks's Avatar
I'm going to vote on the throw out bearing as well. When bearing go bad they chirp. There really isn't anything else it could be if you said everything else checks out.
Old Mar 6, 2006 | 10:17 PM
DelMarVa
great now we gotta break it down again.... uh
WRX1316_TcVicent
Jul 22, 2021 06:06 PM
Mjdavis1994
Sep 21, 2015 04:42 AM
5N1PE5
Aug 3, 2015 11:25 AM
