ALIGNMENT
Old Mar 6, 2006 | 04:25 AM
05CAMO's Avatar
Default ALIGNMENT
Question:
With a drop of like 1.5 to 1.8 " how many of you found it necessary to have an alignment done ?
Old Mar 6, 2006 | 05:58 AM
hnefrdo's Avatar
I've been told that one should get an alignment after tampering with the suspension components in any way.
Old Mar 6, 2006 | 12:29 PM
xA_Factor's Avatar
Yes, your front toe will be out a little.
Old Mar 7, 2006 | 07:47 AM
gnar-de-gwar's Avatar
toe out? i wish! it'll toe in when lowered
Old Mar 7, 2006 | 09:04 PM
xA_Factor's Avatar
Umm should be toe-out.....unless there was a pre-existing toe-in situation before the spring install.
Old Mar 7, 2006 | 10:01 PM
sseward's Avatar
I dropped my box nearly 2" 2 weeks ago using Tanabe DF210 springs. I let it settle and took it in to the dealer for an alignment today. Everything checked out good...within spec, except for the right rear. The spec for Toe on the rears is 0degrees to .33 degrees, mine is .53 degrees. Camber is -.5 to -1.4 degrees, mine is -1.6 degrees. They said they can't adjust the rear. That make ssense given the solid rear axle. The funny thing is, the front was in spec, although I notice that they didn't "center" it. If it was in range, they left it. So, paid for an alingment and nothing got adjusted. Not sure if I should worry about the right rear or not.
Old Mar 7, 2006 | 10:11 PM
05CAMO's Avatar
I've seen other comments with exactly the same results. That's really why I'm asking.
My " dealer" also recommended the work but why not .. it's not his $$.
I'm just looking for some comments from real users.
Thanks.
Old Mar 8, 2006 | 07:37 AM
hmm...i dunno...maybe you toed-out? when i took my car for an alignment my front left was WAY too much toe-in. Anyway...it IS recommended to have your alignment done after suspension work. I guess sometimes, some people have no alignment issues and some don't. I got my alignment done mainly because of performance reasons (I had them set my toe to 0.0, cause you know...factory specs come with toe-in)
Old Mar 8, 2006 | 07:16 PM
Rocket's Avatar
I lowered mine about 1 1/2" and It took an alignment and front camber kit. I now have no tire wear and it drives striaght!
Old Mar 8, 2006 | 08:44 PM
hotbox05's Avatar
i'm slammed 3.25 inches up front and my alignment is damned near perfect still within stock specs
Old Mar 8, 2006 | 09:10 PM
RTon20s's Avatar
Darren, I have seen you mention your drop in the past as 3.25". I was curious what you were using for springs. I thought I remembered reading somewhere that you had some sort of modified Celica springs or something.
Care to fill me in on the specs. of your suspension?
Old Mar 9, 2006 | 12:48 AM
BrianxB's Avatar
last I read i think he was using cheap coilovers, ground control maybe?
Old Oct 22, 2006 | 03:03 PM
Taugenichts's Avatar
Originally Posted by sseward
... The funny thing is, the front was in spec, although I notice that they didn't "center" it. If it was in range, they left it. So, paid for an alingment and nothing got adjusted..
Same thing happened to me but on my camber.. front was Left -0.7 Right -0.9 (specs show -1.3 to 0.2)... should i take it back and just give them the specs that i want? (Toe was also not centered... it was left at -0.05)
Old Oct 24, 2006 | 09:08 PM
applesrfriends's Avatar
get one of those lifetime warranty for alighnment. i think its worth it imho
Old Oct 26, 2006 | 06:13 PM
ppluche's Avatar
What about if I just upgrade wheels?
Since my last and olny service, my tires were totated. And I started to feel that the car pulls me to the left. Then I upgraded wheels and OTG rear shims. I guess I do need a 4 wheel aligment, right?
Do you guys think PepBoys it's a good choice instead the dealer?
Old Oct 31, 2006 | 03:25 AM
bB2NER's Avatar
Music City Scions
I switch back and forth from my Hotchkis springs to stock ones and have never needed an alignment. No tire wear problems either.
Old Oct 31, 2006 | 03:59 AM
06B0X's Avatar
I just dropped on Tein H-techs and monroes in the rear
The new wheels/tires are getting installed tomorrow and I'm having them do a 4 wheel alignment also - just in case.
Old Oct 31, 2006 | 02:08 PM
bB2NER's Avatar
Music City Scions
/\/\/\ You shouldn't have to do one for just springs and rear shocks. I also don't think the rear alignment is adjustable.
Old Nov 14, 2006 | 04:15 PM
lahub's Avatar
06BOX
Am very innterested in how your ride is withe the H-techs and the Monroes. Want to put those on my box and wondered how it would be.
Old Nov 14, 2006 | 04:59 PM
bB2NER's Avatar
Music City Scions
Originally Posted by lahub
06BOX
You will NOT be disappointed with that combo.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
gedster314
Regional - Pacific South
Feb 19, 2021 07:51 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Subaru86
Sep 14, 2015 12:51 PM
scionhawaii
Sep 1, 2015 08:14 PM
