(!)Brake light keeps flashing in dash while driving
I have already read other posts related to my topic, but they were sort of outdated. So i am going to re-explain my problem. I have a 2005 Tc with 40,000 miles on it. The brake light just recently starting flashing (never stays lit). I checked my rotors, pads, and brake fluid and all are fine. Has anyone else had this happen to them recently.
Do you have a 5 spd? B/c it sounds like the ebrake handle isn't all the way down. And maybe it's bouncing when you're driving - hence the flashing of the light.
You might just have to have the handle adjusted.
It means you need new brake pads, I was having the same problems and I added brake fluid and went away, but sice the brake fluid was low, it means I need to change my front brake pads, BTW, I have 54K miles and I have only changed my brakes once.
I am aware of waht the tire pressure guage looks like and it is not that. The word brake starts flashing when i brake and after i push the gas and let off the light goes away. I do not see how it could be the brake fluid when I have checked it and there is more than enough in there. I do not have a manual trans. So I am not always using the parking brake. I am completely confused.
Well, the eBrake handle for the auto is likely in the same place as the 5spd... so it could be the handle still. I'd make sure it's down all the way. The BRAKE light comes on when that handle is up. So it's either not down all of the way or needs to be tightened.
If it's coming on when you press the gas, it's probably b/c that's when momentum might be pushing the handle up a little... then when you let off, the handle falls back down.
your brake pads are dying,
so the brake fluid runs low when the brake pads are thin.
it means its near time to change your pads.
dont believe me? keep driving until ull hear ur brakes squeal.
yep i had the same issue like at 18k miles though lol i need to lay off the brakes
as stated before, i had this problem, everytime i accelerated harder than usual the red "brake" light would flash. took it to the dealer, and they topped off the fluid, and the problem disappeared.
didn't happen every time, but once in a while
