Where can I buy O2 bypass/sim for 05 xb
Old Mar 8, 2006 | 09:29 PM
Makoblaster's Avatar
Default Where can I buy O2 bypass/sim for 05 xb
Hey guys, im looking to get a bypass to get rid of the CEL from the removal of my cat, where would the best place to get a simulator for by box. any help would be appre.
Old Mar 8, 2006 | 10:27 PM
kzhorse's Avatar
Strictly Scionized
This may or may not work with your situation but when I had my S-10 all I had to do was move the O2 sensor about 2' down the pipe and that cleared my CEL.
All it needed to see was a few degrees cooler air.
Scott
Old Mar 8, 2006 | 11:05 PM
RTon20s's Avatar
Why, may I ask, did you remove the catalytic converter?
Do you really think you gained anything besides the joy of seeing the CEL glow on your dash?
Old Mar 8, 2006 | 11:27 PM
kzhorse's Avatar
Strictly Scionized
Well in my case the truck had 156K on it and the cat was busted so I decided to go true duals with 3" side pipes.
With it being a 96 all I had to worry about was the OBD2 not throwing a code to make it thru inspection.
Scott
Old Mar 9, 2006 | 08:57 PM
WeaponR_Ray's Avatar
We have CEL eliminators available.
http://www.weapon-r.com/store/agora....&ppinc=search2
Old Mar 10, 2006 | 02:33 PM
according to your site, that part is for the tc,will it still work for a xb? the page said that the parts where tested for the right carb flow for the application. i need to know if it will work for the xb, cause i dont want to buy a part that will not work with my car.
Old Mar 20, 2006 | 10:21 PM
flxb05's Avatar
DeepSouth Scions
Why would you remove the cat from a new car?
Old Mar 20, 2006 | 11:01 PM
RTon20s's Avatar
Because he probably has no idea what he is doing and thinks he is going to see "big power gains" by replacing the cat with straight pipe and an O2 sim.
Old Mar 20, 2006 | 11:07 PM
Our CEL eliminators work for all OBD2 and up vehicles.
Old Mar 21, 2006 | 03:54 AM
flxb05's Avatar
DeepSouth Scions
Yeah, I guess the factory didn't know what they were doing when they put it together...emissions equipment really kills the fantastic performance on the Xb. [/quote]
Old Mar 27, 2006 | 05:55 PM
Gothbox's Avatar
Why do you have to be such a smart a$$?
Maybe he has a need to. I for one removed mine to on purpse get the most free flowing exhaust as possible so I would have extra gas in the tailpipe so I can do a flame thrower at the back like the old hot rods b/c that is the style I am going for with my car, so I guess that means You are a DUMB A$$111
Old Mar 28, 2006 | 05:58 PM
JoeDarkness's Avatar
Anyone know if this thing really work?
http://cgi.ebay.com/ebaymotors/Steve...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/O2-Se...spagenameZWDVW
Old Mar 28, 2006 | 10:12 PM
dugzilla's Avatar
for the price it can't hurt to try it.
Old Mar 28, 2006 | 10:25 PM
dredge38's Avatar
i just emailed the guy to see if these would work for us, im planning on putting a bypass valve on my exhaust right after the header so i can open and close it the valve to have straight through exhaust and i dont wanna have the warning light come up
Old Mar 29, 2006 | 02:43 AM
Cool, let us know his answer
Old Mar 29, 2006 | 05:00 PM
dredge38's Avatar
he said that i wouldnt need it but im still kinda wondering though, i also didnt ask him about just removing the cat or anything im guessing it would work for that, the guy didnt seem to be to much help to me, i guess ill just have to try my set up without it and see if it works with out throwing a cel
Old Mar 29, 2006 | 11:37 PM
Let us know and update all the info! Thanks!!!
Old Mar 30, 2006 | 03:45 PM
suspended's Avatar
http://www.02simulator.com
now partially i do have to agree with rton20's, the only time removing a cat is going to help is with turbo cars where backpressure isn't really needed, for an n/a motor without high compression and full rebuild, removing the cat will just make your exhaust loud, and make you lose back pressure.....less back pressure=less torque...i've seen automatics stall out at part without cats b/c there wasn't enough comperssion to keep up the backpressure of a straight pipe.
Old Mar 31, 2006 | 08:58 PM
Not agree at all. The catalytic converter with passing the time its converted as a big cork. You can replace with a resonator and you will don't loose compression and does not make the exhaust louder.
Old Mar 31, 2006 | 11:55 PM
dredge38's Avatar
Well im ordering the parts tommorow, the exhaust place is gunna charge me around 60 bucks to do it. Again im not doing this in hopes of gaining any hp or anything really, just doing it so at shows i can pull in with an open exhaust and normal driving ill hit a switch and it will just be the regular through my greddy exhaust. Ill let ya know how things turn out.
