MP3 Problems
Old May 20, 2004 | 05:11 PM
jarhed1's Avatar
Default MP3 Problems
I seem to be having problems creating MP3 discs. I'm only getting one or two files out of 70 on a disc to work. Can some one give me explicit directions on labeling the tracks, or whatever it is I'm doing wrong? Is using Direct CD a problem? Should I not close the disc once I'm done? Help!
Old May 20, 2004 | 05:32 PM
tbblizzard's Avatar
if you're using windows xp just open the cd drive from my computer, it will show an empty folder, then just drag your mp3s over to the cd drive and it will copy them over temp. then click write these files to cd on the left and it will open up the write dialog asking you to name the disc and what not, just go through all that stuff and proceed to burning.
use folders to seperate your music if you need to. folders have nothing else to do with it, just for organizing. lemme know if you got problems still.
i only use programs for buring when i need to burn iso images and what not, windows does a good job for burning everything, it's pretty quick and i haven't had any problems with messed up files or skipping discs. i have 6 discs full of mp3s in my hu, none of them have problems, used windows to burn them all.
Old May 20, 2004 | 05:42 PM
LAVA_XB's Avatar
Default use nero
i use nero to burn mp3 on a cd .........do not make an audio cd make a file cd and drag the mp3's on it.... i fit about 150 tracks on one cd that was mp3 real cool even displays the names in the lcd screen
Old May 20, 2004 | 05:49 PM
profecy's Avatar
what programs are you using to create your mp3 disc. Make sure you burn it as a data disc and also that there are no wma wav files because or mp3 players can only read mp3 format
Old May 21, 2004 | 07:17 AM
NisAznMonk's Avatar
check out this link. It might have some answers for you.
https://www.scionlife.com/forums/vie...911&highlight=
marshallinPA
Apr 8, 2015 02:05 PM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
SCI_FIRE
31
Jan 10, 2004 12:14 AM
