powerslot big brake conversion kit
Old Mar 14, 2006 | 12:53 AM
Kilo6_one's Avatar
Default powerslot big brake conversion kit
I hope I put this in the right section......
anways after much research and debate, I decided to instal a powerslot 13.5 inch conversion kit in the front. It took about 2 hours to install, considering i installed SSbrake lines and changed the fluid to synthetic.
Also I upgraded the pads to some axxis metal master pads, anyways it stops much better and the pedal responce is far better, I dont track my car so I did not see the need for a full 4 pot conversion. But with 19's I felt the standard brake set up was too sloppy.
Also it looks really nice it definatly fills up the rim as you can see.........
total mod cost about 700.00
If you dont have anything postive to say, keep it to yourself.........
Old Mar 14, 2006 | 12:54 AM
Kilo6_one's Avatar
oh yeah painted the calipers black......
Old Mar 14, 2006 | 12:55 AM
chubster41's Avatar
looks awesome.....
Old Mar 14, 2006 | 01:48 AM
Neothin's Avatar
is 13.5" the standard rotor size for the powerslot plus rotor upgrade? i thought it was 12.8" (then again, my memory isnt the greatest :D). I've been wanting a larger rotor to go behind my wheels. The stocker just looks so small behind 5 spoke 18's.
Old Mar 14, 2006 | 02:36 AM
Kilo6_one's Avatar
sorry, my bad.........it is 12.8
Old Apr 23, 2006 | 03:57 PM
madigan923's Avatar
i didnt even know these exsisted untill sport compact car mag put them on their tc. the article was great w/ some great info. once i saw them i fell in love.. just need to start putting the $$$ asside. they look great btw. I hate the look of stocker's behind any wheel size bigger then 17. kinda wish they offered crossdrilled as and option thou.
Old Apr 23, 2006 | 06:28 PM
Kilo6_one's Avatar
they used to have cross drilled when AEM was marketing them, there is a guy on here that is parting out his Tc and has them for 350 for the kit.
here is the link to his thread......
https://www.scionlife.com/forums/vie...10105&start=50
Old Apr 23, 2006 | 07:12 PM
d_gage's Avatar
wow that looks GREAT!!!! any plans on doing the rear kit as well?? MORE PICS too
Old Apr 23, 2006 | 07:17 PM
Kilo6_one's Avatar
eventually...ill do the rears, but since the rear brakes dont do much other then balance out the braking its not really nessacary at this point
Old Apr 23, 2006 | 07:21 PM
d_gage's Avatar
gotcha, have you tried to put the stock wheels on with this brake package on??? im just curious if it will fit. also where did you buy it from?? thanks for answering all of my BS questions
Old Apr 23, 2006 | 08:34 PM
Kilo6_one's Avatar
they are not BS questions......
i have 18x8 advans, i have never tried to put it behind a stock wheel, but it will fit...all you are doing is moving out the caliper about 2 inches.
the picture of the rims is not current......
this is the current image
Old Apr 23, 2006 | 08:38 PM
d_gage's Avatar
wow those truly look GREAT!
Old Apr 23, 2006 | 08:51 PM
Kilo6_one's Avatar
i wish the bolts on the rotor hat were a little nice.......but oh well.
thanks for the compliment, i paid like 500 plus shipping..
Old Apr 23, 2006 | 08:53 PM
d_gage's Avatar
no ____ were did you pick them up from???
Old Apr 23, 2006 | 08:58 PM
Kilo6_one's Avatar
some guy on ebay.......i think he raised his price thought to like 525 shipped
Old Apr 24, 2006 | 03:46 PM
j3st3r's Avatar
Music City Scions
Looks like the rotors are on backwards....the gooves usually point forward.
Old Apr 24, 2006 | 04:04 PM
The_Instigator's Avatar
Rotor slot direction is not an issue if they use a straight vein rotor. If the rotor has directional internal veins the slots should be in the opposite direction to maintain maximum rotor strength. Im pretty sure the Powerslot rotors are straight vein rotors which means there is no "correct" way for the slots to face.
Old Apr 24, 2006 | 04:07 PM
j3st3r's Avatar
Music City Scions
Looks to me like they are curved veined and in that case I am wrong. There is a certain direction curved veined rotors should be installed, and in that case he does have them installed correctly.
So why does Foose and Bear install there straight veined rotors that way then?
Old Apr 24, 2006 | 07:42 PM
klepto's Avatar
they look good. I too want to upgrade the braking system. Seems like the OEM just isnt adequit enough....
so these are just OEM replacements right? Not neccessarily BIG BRAKE KIT? I think if i am not mistaken even w/ the BIG BRAKE kit version all you need minimum is 17" wheels or larger. If you clear the caliper fromt eh wheels even by 2 cm....that is more than enough space. Object is No rubbing at all thats all.
Old Apr 24, 2006 | 08:36 PM
Its not a true big brake kit...just a rotor upgrade with move out brackets for the stock calipers. You dont get the benefits of a big brake kit likse stiffer calipers, better pad selection, or increased heat capacity due to a larger pad.
