rs1028tc
03-14-2006, 05:10 AM
Yo yo yo
I was wondering if there is a way to have the turn signal lights on all the time and blink when your turning left or right. I saw this on a ford work truck and it looks awesome. I just wish there was a way to do it on our cars
Tomas
03-14-2006, 07:39 AM
Should be easy enough to do with a couple of relays. Have the relays follow the flasher and connect the lights to the NC instead of the NO contacts. That should reverse it just fine.
integsrtite
03-14-2006, 11:50 PM
yep but the high resistance of the relays would cause hyperblink. so (unless you want hyperblink) you'll need to get some ~1ohm high power (~21W?) resistors in parallel with the relays. http://www.v6performance.net/forums/showpost.php?p=902017&postcount=19
a friend of mine used those to do a similar thing to his 7thgen accord
Tomas
03-15-2006, 01:23 AM
Yup, it could, Alan, but it also depends on the solid state flasher circuit used, and the relay coil's resistance. If the flashing goes nuts, what you suggest is the simplest fix. :)
