weird sound when shifting
Old Mar 15, 2006 | 04:48 AM
JINeration's Avatar
Default weird sound when shifting
ok im gettin paranoid wen im driving then shifting into gear like the first or seond i hear like the trans poping sound and wenever i down shift it does it too
or is it that i need to cdhange the manual trand fluid
when are u suppose to change it newayz
Old Mar 15, 2006 | 12:38 PM
JINeration's Avatar
28 views buh no answer....
Old Mar 15, 2006 | 12:41 PM
zm_br's Avatar
how long have you had the car? i've noticed that my tC is a little harder to shift when first driving than after it is warmed up a while. even compared to my supra, it seems to grind a little...
Old Mar 15, 2006 | 09:58 PM
chrischoi's Avatar
clutch pushed all the way in?
Old Mar 15, 2006 | 10:30 PM
zm_br's Avatar
yah, i thought that might be my problem also. but, i always have my clutch all the way in.
Old Mar 16, 2006 | 12:23 AM
versello's Avatar
I have the same problem as well... after driving around for a bit, it seems to be fine.
Old Mar 16, 2006 | 12:28 PM
zm_br's Avatar
maybe the transmission fluid hasn't warmed up yet? i wanted to wait until the summer to see if it still made noise.
Old Mar 17, 2006 | 02:59 AM
JINeration's Avatar
no i dun think its that it still does it after its been warmed up
Old Mar 17, 2006 | 03:49 AM
rs1028tc's Avatar
i hear a soft/faint psssh. it sounds like a mini blow off valve i dunno what it is
Old Mar 17, 2006 | 07:46 AM
Tenaj's Avatar
the pssst is most likely your intake (even if stock) I know my tC did it as well
no idea on the shifting noise, my clutch on the civic was making some wierd noise for a lil bit today as well...
Old Mar 17, 2006 | 07:59 AM
rs1028tc's Avatar
do you know if there is anything i could do to my stock intake to make that sound even louder, it sounds so nice and soothing lol
Old Mar 17, 2006 | 08:01 AM
kileil's Avatar
If its a 'tink' noise its common on Tcs and not a problem. Drive down a street lined with close buildings and a windows down, if you can hear it more clearly and it sounds like a solid engagement of metal its just the shift linkage.
If its a grind, well thats a problem.
Old Mar 17, 2006 | 08:03 AM
rs1028tc's Avatar
hey kileli where in milwaukee are u from, im also from milwaukee if u got aim hit me up at pipster78
Old Mar 20, 2006 | 06:43 PM
BionicJuic3's Avatar
Add a CAI, i have INJEN and it sounds awsome...
Old Mar 21, 2006 | 02:22 AM
cfusionpm's Avatar
hey, i see you play IDAS. i used to be hardcore into it. http://cfusionpm.com/initiald/
Old Mar 21, 2006 | 04:49 AM
FireStorm's Avatar
Ive had some strange noise when i'll drop to second gear and it sounds like a loud Breaking as if my engine was slapping the fire wall.
Only when in second gear though...there was a tiem i thought i put it in third but second and i went from like 1000rpm to about 5000 pretty quick on accident. And it made the noise again =/
Old Mar 21, 2006 | 05:01 AM
kiasutoo's Avatar
I have the same issue too. First I though it was a fluk, it became more and more annoying. Brought it back to the dealer (1K miles) , they tighten a couple of bolts... problem still exist. Finally I had enough and traded it in for a 06'. The 06' don't have this issue!!
Old Mar 22, 2006 | 11:19 AM
Kennopee's Avatar
Default Re: weird sound when shifting
I believe that transmission fluid is especially thicker than other oils in your car. So in the winter, you'll feel those rough shifts. The problem goes away after your car is warm, and this problem doesn't usually pop up in the summer, unless there's a really chilly night.
Old May 2, 2006 | 04:26 AM
summerofsam44's Avatar
Yeah i think it might be that. I hear the exact same noise in my 06. It seems to be louder going from first to sec. then as I go threw the gears it gets even more quiet. I think it is just the shift links.
Old May 2, 2006 | 06:02 PM
Diluvium's Avatar
tinking sounds are common... if you can drive smooothly then theres nothing wrong....
as a matter of fact all TOYOTA manual transmissions have that tinking sound.... i thought there was something wrong too but i checked the xB and Celica an they all make that noise...
