17 inch rims on a xB?
Old May 21, 2004 | 06:13 PM
Ali_La_Pointe's Avatar
Default 17 inch rims on a xB?
Im thinking about popping on some Axis TC Evos. Was wondering if 17 would be an ok size. I am going to be driving A LOT (about 300-400 miles a week) and wanted to know if these would be safe to ride on. Also, i do not plan on lowering the vehicle.
Old May 21, 2004 | 06:37 PM
xtremeOrange's Avatar
Search. Use it.
Old May 21, 2004 | 06:45 PM
daboxinsl's Avatar
I ride on 17's right now and do about 350 a week...great ride...no problems
Old May 21, 2004 | 06:50 PM
BlueBox's Avatar
i'm running 17s as well. with 215/45 nitto tires... although mine is lowered 2".... i have never scratched the bottom of my car. and i drive about 600 miles per week..although mostly on freeways to work..i live far from my work.
Old May 21, 2004 | 06:55 PM
well Nilo set me str8. I decided to go with 18's. What kind of tires should i get though? Im going to be moving to massachussetts so i know that when the weather gets going, im gonna have to ride stock again
Old May 22, 2004 | 03:30 AM
Chris101's Avatar
What is the width of your 17's. Does the large tire size throw off your speedo.
I.m runnin 17x7's 205/40/17 and thinkin about 205 or215/45/17's thanks
Old May 22, 2004 | 04:37 AM
Sid_xBicious's Avatar
thanks to you guys, i'm also running on 215/45/17. no rub, and a little smoother ride than 40's(more wall).
http://www.miata.net/garage/tirecalc.html
speedo is off by 3.7%, on 60mph were actually traveling 62.2 mph, not much of a difference, i drive like a granny anyways(looking for potholes to avoid
Old May 22, 2004 | 01:42 PM
macncheese's Avatar
Im not sure where you're located now but MASS isnt known for it's velvety smooth highways summer OR winter. I'd avoid 18s if I were in your shoes.
Cheese
Old May 22, 2004 | 05:15 PM
Im not going to lower the car though.
Old May 22, 2004 | 05:22 PM
Longoscion's Avatar
you can fit 19inch tc evos no problem.
Old May 22, 2004 | 05:55 PM
rjsalvi's Avatar
Do you have any rubbing anywhere when cornering hard? I assume if it works on a 2" drop, it'd be fine with stock? Thx.
Old May 24, 2004 | 04:40 AM
BlueBox's Avatar
i haven't had any type of rubbing as of yet..even with my 2" drop.
Old May 25, 2004 | 02:13 AM
tinybigrig's Avatar
i dont rub either with a 2 in drop, but now i may be selling my maglites, for a set of 20s.....i know i know, i always hated on dubs, but these are sweet, unreleased axis dubs in a 20 x 7.5, which "should" fit without rubbing
brent
Old May 25, 2004 | 02:31 AM
jynx's Avatar
what wheel offset are you guys running?
Old May 25, 2004 | 06:55 AM
BlueBox's Avatar
i'm running +40 offset
Old May 26, 2004 | 02:31 AM
tinybigrig's Avatar
40, although if i could have custom offsets, or a choice i would run 35ish in the front and 25ish in the rear, making everything flush
brent
Old May 26, 2004 | 11:53 AM
CBSIMONSEZ's Avatar
Im running a 215/45R17 as well, on a 40MM offset wheel too. I did have to fit a 3MM spacer on the front to clear the caliper, and i do have minor rubbing issues at full turn on the steering wheel. The rubbing is on the plastic inner fender, and will wear itself flush over time. BTW, im also riding with a 1 inch drop with the Tein H series, much better ride now over stock.
Old May 27, 2004 | 09:44 PM
TheScionicMan's Avatar
brent
Did you need spacers for your maglites?
Old May 29, 2004 | 10:20 AM
tinybigrig's Avatar
naah they fir fine, but i keep thinking about spacing the rears out so they are flussh, but we are gonna test fit the 20s on wed i think so we'll just have to see
brent
rvascion
Nov 12, 2020 03:23 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
peruviann
Sep 14, 2015 06:35 AM
Robineileen324
Sep 14, 2015 06:21 AM
JZA70
Sep 12, 2015 09:37 PM
