Adapter to make steering radio controler work on A/F deck
I HOPE THIS'll help those who love the convenient of steering radio controler , by the way. i just ORder it .. i'll update this post with picture how to . once i install it in my 06 Tc
link 1 this adapter only for alpine deck ,This adapter is also compatible with select JVC and Kenwood radios with wired remote inputs
http://www.crutchfield.com/S-GzSpvfa...sp?i=127SWIALP
link 2 Pioneeer and sony deck adapter , Will only work on Sony radios that have an input for the RM-X2S, RM-X3S or RM-X4S wired remotes. For Pioneer radios: Unless noted, the SWI-PS will work with all Pioneer radios that have a Steering Wheel Remote input
http://www.crutchfield.com/S-GzSpvfa...+ps&i=127SWIPS
guide how to : please download it
http://www.megaupload.com/?d=9J43S6O6
need microsoft word to read this article!
now finally gots ome time to write this how to ..
first of all look for steering wheel radio control plug.. (swc) located indash where ur radio harness are. please check picture for plug shape . and detail
Second step : : wiring..
The SWI-X's interface wire color we are going to use is White. This is the White wire on the SWI-X, not the vehicle!
The other wires on the SWI-X, green, yellow, orange and blue wires are not used for your Scion TC.
This leaves you with a Red, Black and two loop wires. These wires will be discussed down below.
note: SWC = steering wheel control
Connect pin 6 wire to ground(black wire on the a/f radio harness) Connect pin 7 to the INTERFACE's White wire. Connect one end of a 150 ohm resistor to pin 8, then connect the other end of the resistor to the INTERFACE's white wire. So basically you will have two wires, one with a resistor in series, connected the the INTERFACE's white wire.Black wire: Connect the SWI-X's black wire to chassis ground. This is usually a black wire on the aftermarket wire harness.
Red wire: Connect the SWI-X's red wire to a switched +12volt wire. This is usually a red wire on the aftermarket wire harness.
i'll look like this when u done .
resistor : picture below
step 3 programing :
please follow these step in picture below
http://img71.imageshack.us/my.php?im...graming6pz.jpg
http://img122.imageshack.us/my.php?i...graming9qw.jpg
hope this useful
step 3 programing :
hope this useful
step 3 programing :
hope this useful
step 3 programing :
hope this useful
