dc sport header?
Old May 22, 2004 | 07:32 PM
profecy's Avatar
Default dc sport header?
So my question is i just got the dc sports header and was wondering if it ruins the warranty and if there is a possible way it can ruin the box besides ruining the mileage? also while installing it do u need to get a new gasket for it im not sure wat the word is
Old May 22, 2004 | 11:04 PM
kwicslvr's Avatar
1. Warrenty....yes and no. It has to be the cause of the part that breaks.
2. Ruining the box....nope.
3. MPG...Actually it will increase with like conservative driving due to less backpressure causing the engine to produce work easier. Granted under a heavy foot it will be worse a little bit. +/-~2MPG.
4. Being so new...probably not...but it never hurts. I always change gaskets when one is required to be used.
Old May 23, 2004 | 07:04 PM
profecy's Avatar
thanks alot so did u change the gasket when you installed the headers
Old May 23, 2004 | 07:05 PM
kwicslvr's Avatar
I haven't installed mine yet but I will change the gasket when I do it.
Old May 23, 2004 | 08:07 PM
bBted's Avatar
u dont have to change gaskets...our cars still new....maybe thats the reason why it dosent come with one
Old May 23, 2004 | 08:47 PM
Minsk99's Avatar
I reused the stock gasket. My xB is like three months old. The gasket looked and felt like new so it didn't seem necessary.
Old May 23, 2004 | 11:20 PM
turbomx5's Avatar
How hard was the instal?
Old May 24, 2004 | 12:26 AM
Minsk99's Avatar
Installation is easy. However, I used an air impact wrench on the two spring bolts that hold the header onto the exhaust pipe that leads to the catalytic converter. I have no idea how hard these bolts are with hand tools. From what I've read from others on this site I think that its not a problem. Installation took me under 45 minutes. DC instructions were simple and easy to understand. FYI, I had to jack up the car in the front and slide underneath to get easy access to the spring bolts. The only special tools that you might need is a long extension for any type of ratchet or wrench you might use. I used a 10" extension.
Old May 25, 2004 | 05:09 AM
profecy's Avatar
my car is alittle bit over 7 months old so i might want to change the gasket where can i get a new one at for and how much is it goin to cost
vi3tb0i09
Sep 23, 2015 08:32 PM
ScionLife Editor
Sep 16, 2015 10:00 PM
prescottn
Sep 13, 2015 09:04 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:27 AM
ScionLife Editor
Sep 8, 2015 07:10 PM
