View Full Version : Air ride Suspension?
MrMcNuggett
05-24-2004, 04:23 PM
Anyone know if they are making a airride for the xB. Got to have that. 8)
onesicbowtie
05-24-2004, 04:36 PM
I know there was a shop working on an air bag kit for the xb out in san jose cali
WWW.SICMOTORSPORTS.COM You might want to check with them
BoomBox757
05-24-2004, 04:48 PM
http://www.scionlife.com/forums/viewtopic.php?t=11047
sadistic1
06-05-2004, 04:14 PM
for 1500 dollars i can send you a bolt in kit with new struts in the front so you can go back to stock when ever you what
the kit includes
2 bagged strut for the front with fittings
2 slam specialties bags with cups for the rear with fittings
1 viair 380
1 3 gallon tank
6 gc 450 psi 1/2 valves or 3/8 depending on what you want
set of fittings
3/8 dot air line for ease of movemant in tight areas
3 cole herse long toggle switches
and instruction
sadistic1
06-05-2004, 04:22 PM
plus shipping and tax if you live in CA
rcstprez
06-05-2004, 04:37 PM
why 6 valves instead of 8? I'm guessing this is just a f/b kit.
what holds the rear cups in place from dropping out at full up? or do the bags not lift enough to get to that point? (I have heard slam spec. gets the most lift of any other brand).
sadistic1
06-05-2004, 04:50 PM
the rear cups are bolted in and the shocks limit the travel up .above stock height is good. the reason for only 6 valve because using 4 in the back is a waste you cant get a true side to side in the back because of the straight axle and the torsion bar
rcstprez
06-05-2004, 04:54 PM
..and you use strut bags up front or cyls.?
how big is that tank..I was thinking a pancake tank would clear stuff better?
sadistic1
06-05-2004, 05:00 PM
new struts with bags installed 3 gallon tank its about 20 inches long 6 inches in diameter. i pic the round three gallon for ease of install between spare tire bubble and rear bumper under car everything mount outside under rear trunk area so there room inside for speakers amps or soforth
rcstprez
06-05-2004, 05:14 PM
few more q's..
how long does it take that compressor to fill the 3gal tank?
how much (estimate) is shipping to n. Florida
what forms of payment do you accept?
I thought I saw once that you had a website?? if you do, what is it..
sadistic1
06-05-2004, 05:31 PM
from totally empty approx. 5 mins. from from when the comp. turns on at 100 psi via pressure switch (included) to the 185 psi mark approx. 2 min
to ship to florida i have to get a final wieght and find out
the website is www.sadisticiron.com
check, money order, western union, cashiers check
waiting for credit card machine
