View Full Version : Dumb fuse question
summerofsam44
03-25-2006, 04:48 PM
Where is the fuse for the cigarette ? I was putting my short shifter and when I unpluged it it sparked but I cant find the fuse for it.. Can you help me?
thanks
tikbhoy
03-25-2006, 06:01 PM
lay down and look up underneath the steering column. its covered with a rectangular black plastic. i cant find the same size of fuse but mini fuses will fit BUT the cover wouldnt work with it
summerofsam44
03-25-2006, 06:27 PM
You mean the one right above the hood release right? Yeah I looked there as well and could not find it
Rodeo727
03-25-2006, 07:50 PM
No. It is down below all of that under the steering column, like he said.
tikbhoy
03-25-2006, 07:56 PM
next to the odb2 port
you need to bend over more and LOOK below!
PrivateTucker
03-26-2006, 04:32 AM
place your head on the floor and look up. Also, they're the mini-blade fuses, so make sure you have direct replacements, or you will not be able to place the cover back over the fuses.
SquallLHeart
03-26-2006, 05:28 AM
uhh.. doesn't the cigarette one have an in-line fuse also?
watcher1307
04-04-2006, 09:43 AM
Yes the cigarette lighter has a fuse. MOST definatly! Almost everything in your car does. They might not all be in the same spot, but they're there! So Their!
