Power Distribution Block
Old May 24, 2004 | 11:07 PM
dlnchbx's Avatar
Default Power Distribution Block
I was planning on wiring my amps myself, just one quick question. Where should I install the distribution block? closer to the battery or closer to the amps?
Old May 24, 2004 | 11:09 PM
EMU's Avatar
EMU
amps
Old May 24, 2004 | 11:35 PM
Silencei2's Avatar
Default Capacitor
Depending on what you're running you might want to consider a capacitor and the ideal setup would be running a capacitor with a distribution block otherwise you should just wire the amp, distro block, and cap all as close together as possible
Old May 27, 2004 | 01:55 AM
bspxB's Avatar
EMU is right, mount the db closer to your amps. You will only have to run one wire through the firewall. Just make sure that the wire is the proper gauge for your amp's power requirements.
Mike
evolving_machine
Oct 21, 2023 01:16 PM
xa007xa
Mar 29, 2015 10:28 PM
akwdcaveman
Jan 28, 2015 07:56 PM
mrsocks
Jan 20, 2015 01:29 PM
crystaljukebox_com
Feb 5, 2004 05:53 AM
