Help - One of the OEM fog bulbs went out and can't get to it
we tried to do it from under, but the washer fluid res is in the way on the passenget side.
do you remove the fogs, if so, how, they snaped in place when installing them
How do you change the oem fog bubls please someone.
thanks
XOX
thanks
XOX
Easy fix:
1. pop hood
2. remove upper grille (3 plastic fasteners on top)
3. unbolt top of bumper cover (4 bolts & 1 plastic Fastener) 1 bolt on the fender by the front tires each side, 2 where you took out the front grille.
4. Pull out on the sides of the bumper cover by the front tires, then forward.
bumper cover should be free on the top.
5. Pull back on each side to access the fogs tiwst and change the bulb.
6. Put it all back together.
the bulb size is 9006 I would suggest you repalce both with better bulbs like Sliverstars or Luminics.
This should take you 10-15 min.
Peace!!
1. pop hood
Peace!!
will do thanks!!!!!!!!!!!!!!!!
Originally Posted by Pitman
Easy fix:
1. pop hood
Peace!!
1. pop hood
Peace!!
... 2. remove upper grille (3 plastic fasteners on top)...
To remove a fastener, do not pry up on the whole thing, or else ultimately the fastener or part of the car must break to release the grille.
Look for the little indentations on each side of the inner part, insert a screwdriver into the most convenient indentation, and pop the inner part up. It will only come up a little bit and is not supposed to come out. Popping the inner part up un-expands the outer part, which can then be pulled and popped out the the car.
Good point!! I forget that some people on here don't know the obvious.
Thanks!!
...Good point!! I forget that some people on here don't know the obvious...
https://www.scionlife.com/tech/image...grill_xb/1.jpg
I have been wrenching bikes and cars for years, and it's hard to get used to how the Scions are assembled with so much snap, crackle and pop. Well, hopefully no crackle.
Originally Posted by XBRachel
...How do you change the oem fog bubls please someone....
Originally Posted by Max
I was able to reach mine from underneath without removing anything ...
I bought a 2x10x8 ft long, and had the store cut in in two 48" pieces to carry in the xB. I used a circular saw to cut each 48" piece into an 18" and a 30" piece, using a 45 degree cut. Nailed the short pieces on top of the long pieces, and made a cheap 3" high ramp. It is easy to roll up on the bevel cuts, and it is a good height for changing oil (and fog bulbs).
