Tips on install for SRI?
Old Mar 30, 2006 | 01:21 PM
Ghost_1's Avatar
Default Tips on install for SRI?
I just ordered the Fujita SRI for my xB. I was wondering if anyone had any general or specific tips on the install. For instance I know that some people were having to clean the inside of the Injen SRI before install. Or removing the battery to place the filter on the SRI. I have unlimited access to Techs, tools, and lifts, so anything would be nice. Also has anyone tried putting on the filter without removing the battery?
Old Mar 30, 2006 | 02:11 PM
dugzilla's Avatar
you don't have to remove the battery to install a SRI. Check out the DIY in the tech section, it should only take 20-30 minutes to install.
Old Mar 30, 2006 | 03:21 PM
hayalex6's Avatar
There's no way you could mess up a SRI installation. It probably won't even take you 20 min.
Old Mar 30, 2006 | 03:31 PM
ProshopXB's Avatar
I removed the battery when i did my SRI, just to free up alittle space under the hood to make it easier to put it in. But you dont have to, makes it a little easier thou.
Old Mar 30, 2006 | 04:05 PM
RTon20s's Avatar
The instructions from Fujita are top notch. I removed the battery in my wife's car just to make installation easier. You should disconnect the battery to reset the ECU any time you do performance modifications anyway. And the installation really is straight forward, with only minimal tools required.
Old Mar 30, 2006 | 04:46 PM
dugzilla's Avatar
It's a lot easier to pull the fuse for the ECU, that way you don't have to re-set all your presets on your radio.
Old Mar 30, 2006 | 04:57 PM
David_Seale's Avatar
if you have a 06, itll take you a little longer. search for my thread if you do.
Old Mar 30, 2006 | 08:00 PM
Sciond's Avatar
good advice
Old Mar 31, 2006 | 05:26 AM
Spiderbox's Avatar
i have the fujita intake on my car. i'm not 100% sure but i dont think you can put in the fujita intake without taking the battery out, the air filter is huge.
Old Apr 2, 2006 | 03:36 AM
Big_Bird's Avatar
i didnt take mine out when i instaled my sri, i just un bolted it and scooched it over a little bit, more than enough room
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
