Camber Question
Old Mar 31, 2006 | 03:29 AM
Sciontuner's Avatar
Default Camber Question
i see sick ___ camber kits, and i was wondering how the tire wear is? is replacing the tires every 6 months just the price you pay?
question 2 - if i have an air ride setup, will the wheels always be cambered out full air and empty? sorry for the newb questions.....thanks for readin yall
Old Mar 31, 2006 | 04:29 AM
MyBoX's Avatar
Are you talking about the Front or Rear ??
With air ride, there is no camber adjustment in rear or needed but in front you will end up with posetive camber then you need to add camber plates to correct your camber !!!
Old Apr 1, 2006 | 04:47 PM
JDMJim's Avatar
Get canber plates for the front. Camber shims for the back. Yes the tires will wear very fast. I can attest to that.
Old Apr 1, 2006 | 05:05 PM
cherryBox's Avatar
JDMjim - first off you have one sick sick sick ride - are you using cusco or otg?
My understanding was that the otg shims account for the toe in correction necessary to prolong the tread on cambered rears. I'm sure they still wear faster either way.
Old Apr 1, 2006 | 05:07 PM
JDMJim's Avatar
Camber is camber. Tires will wear whether or not the toe is corrected. Best bet is to use them when going to and from shows.
JDMJim's Avatar
And thanks
Old Apr 1, 2006 | 06:28 PM
cherryBox's Avatar
cool...still curious what you are using
Old Apr 1, 2006 | 11:40 PM
MattyRattyPoo's Avatar
IM using Cusco Camber plates for the front and OTG camber shims for the rear. -3 in the front and - 4 in the rear.
Old Apr 2, 2006 | 11:47 PM
JDMJim's Avatar
Cusco on the front and homemade on the back. Like I sid, only for show.
Old Apr 4, 2006 | 06:53 AM
aireck's Avatar
-4 in the rear with just camber shims from OTG.....?? or is there something else?
and the front i'll have the same since im running Cusco Coils.....
i haven't played with camber for the front yet but i guess -3 is the most up front??
Old Apr 5, 2006 | 05:58 AM
I just have OTG camber spacers for the rear. When I got an allignemnet, they told me that I was at -4 degrees camber. It could be the extensive drop that I have with my coilovers.
Old Apr 5, 2006 | 06:06 AM
magicmanjk808's Avatar
-1 is stock. add another -3 and you get -4.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
xBassist
9
Jan 21, 2004 07:34 PM
