Installing Springs
Old Mar 31, 2006 | 02:00 PM
TheIcon's Avatar
Default Installing Springs
I plan on installin gmy spring tonight. Going to follow the step by step in the tech section. It doesn't mention the front sway bar though. I assume this just unbolts from the top? I have never really looked at how it was installed.
Old Mar 31, 2006 | 02:09 PM
BrianxB's Avatar
the front sway will not be that easy if you are trying to replace it. If you are asking whether or not the sway needs to be unbolted if you are replacing springs, the answer is no.
Old Mar 31, 2006 | 05:33 PM
TheIcon's Avatar
You answered my question. Thanks
Old Apr 3, 2006 | 03:07 PM
TheIcon's Avatar
Umm I just checked out the car and it looks like I do need to remove the sway. The screws I need to undo under the hood are the same ones holding the sway bar down Guess I have to remove that to? Anything I should be leary of? Any right wrongn way to remove and put the sway back on?
Old Apr 3, 2006 | 03:28 PM
hayalex6's Avatar
to put on springs there's no need to take off the sway bar.
Old Apr 3, 2006 | 03:34 PM
whaler's Avatar
I think he is confusing a strut tower brace with the sway bar.
Old Apr 3, 2006 | 03:43 PM
TheIcon's Avatar
Yep that is what I would be doing ooops Anything I should worry about here when taking it off and putting it back on?
Old Apr 4, 2006 | 06:23 PM
slimgravy's Avatar
dont out the strut bar back till its back on the ground and drove back and forth. body can flex while on jack stands and might have a hard time getting the bolts to line up with the holes.
Old Apr 6, 2006 | 12:29 PM
TheIcon's Avatar
Say that again? Wait till after i lower my jack to put the strut bar back on?
Old Apr 6, 2006 | 05:30 PM
slimgravy's Avatar
<cant type lol...
yes you have it right.
ScionDP
Mar 1, 2015 10:57 PM
Frustratez
Feb 26, 2015 04:03 PM
kleecker
Jan 9, 2015 02:26 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
randode
18
Nov 19, 2003 03:37 PM
