xB Direct Replacement Speakers/sizes
Old Mar 31, 2006 | 03:06 PM
Straylight's Avatar
Default xB Direct Replacement Speakers/sizes
Yeah...I know...use the search function....and I did.
I remember a long time ago, there was a post here that listed some direct drop in replacement speakers (I believe they were Pioneer part numbers) but no matter what type of search I use, I can't find the post.
If someone can answer this or link the faq post, I'd appreciate it.
I currently have the stock speakers in my xB and am looking for some drop-in, no modification replacements that sound better than stock. Anyone have any part numbers, etc?
Thanks!
Old Mar 31, 2006 | 03:26 PM
ProshopXB's Avatar
I know they have a upgraded bazooka package, i think TRD Sparks sells it. It looks like it drops right in, check it out.
Old Mar 31, 2006 | 05:24 PM
Straylight's Avatar
Bah F that thing. My dealer had a deal with a local shop and instead of the Bazooka package, I have a Fosgate amp and a 10" sub under the passenger's seat in a custom box that sounds tons better than the factory Bazooka tube. I was asking about the other speakers...door/dash/panel that I could swap out. I swear that a few months ago there was a tech post with some specific part numbers for some retail Pioneer speakers...but I'm open to pretty much anything and am curious as to some simple drop-in replacements...something I wouldn't need a shim or spacer for...just a pure drop-in.
Old Mar 31, 2006 | 05:29 PM
dubstar's Avatar
The front speakers are 6 1/2 on the door, the dash are 3" but you need to make an adapter plate so that they fit because most 3" don't have a wide mounting like the factory do, and the rear are 5 1/4.
Old Mar 31, 2006 | 05:39 PM
KYfirefighter's Avatar
check out crutchfield.com you can call them and they are very knowledgable. when you buy speakers from them you always get the harnesses and adapter plates for free.
Old Mar 31, 2006 | 05:58 PM
Straylight's Avatar
Thanks! I couldn't remember about the dash speakers... I know that in that magic post I can't find, someone listed a Pioneer part number to one of their 'oversized' speakers that actually dropped in the dash...with no mounting plates required. Heh I'll keep digging on the net for that one.
Old Mar 31, 2006 | 08:22 PM
champagne_supernova's Avatar
He meant there was a set of bazooka speakers (NOT the sub) offered for sale as an upgraded system in some regions of the country. I have no idea how good these are but they are a direct factory replacement kit.
Old Mar 31, 2006 | 09:13 PM
Straylight's Avatar
Ahh... I don't have any personal experience with any speakers from them other then their subs. I've used MB Quart, JL Audio, and JBL in the past primarily. I'll check them out and see if I can find some reviews.
Old Apr 1, 2006 | 12:12 PM
wagonbldr's Avatar
The Family
Default speaker sizes
Hey Straylight, I am also looking to replace my speakers. I remember from past posts that the dash speakers can be replaced with Pioneer 4", just break or cut off 2 of the mounting tabs Also needs a crossover capacitor to make them tweeters only.. 6 1/4 or 6 1/2 for the front doors and 5 1/4 rears. 6 1/2 can be put in the back, but it requires some modificarion. I also remember the posts with the Pioneer numbers, just can't remember the numbers off the top of my head. I think most were purchased at Wally World.
Old Apr 1, 2006 | 12:54 PM
jrsixx's Avatar
I put Pioneer TS-G1041R 4" in the dash, just had to cut the mounting tangs from circles into a U shape, dropped right in, and Pio TS-G1641R 6 1/2" in the doors, had to destroy the original speakers to use the mounting brackets as the hole on the door is much larger, unsoldered both connectors from the old speakers, and onto the new ones. Also used a 200HZ cap on the 4". all plugs into factory wiring and they sound soooooo much better. Got both for under $100 at Best Buy, but have heard of others getting them both under $50. Good luck
Old Apr 3, 2006 | 03:13 PM
Straylight's Avatar
I popped in the TS-G1041Rs in the dash with a 200Hz cap on them. I could tell an immediate improvement. I also have those 6 1/2s and some Pioneer 5.25s right now ready to go in, but I want to find a really good walkthrough so I don't end up destroying my interior.
Old Apr 3, 2006 | 05:21 PM
Karl_Hungus's Avatar
quick question about the pioneer TS-G1041R dash speakers: what kind of a sound baffle/surround did you make for those? what did you use? It's a strange shaped hole that it sits in.
Also, did most people put some kind of anti-vibration/rattle foam on the sound baffle/surround? Thanks for the help.
Old Apr 3, 2006 | 07:59 PM
Straylight's Avatar
I didn't...there wasn't one on the stock speaker, so I didn't use any on the Pioneer I dropped in.
I probably will with the doors/back panels though, I just haven't gotten there yet.
Old Apr 3, 2006 | 11:03 PM
but, the back of the original speakers were sealed, so they don't need a surround. I think your midrange will suffer if you don't put a baffle around them.
Old Apr 5, 2006 | 01:26 PM
Straylight's Avatar
I haven't dug into the doors and back panels yet (still looking for a good walkthrough or exploded diagram) so I haven't seen what the factory midrange speakers look like.
I've see a few messages from folks saying they trashed the original speakers and used their housing...so I don't know the feasability of this... I guess I will figure something out when I get in there.
Old Apr 5, 2006 | 01:38 PM
ProshopXB's Avatar
You can make your own plates in the front with ABS plastic or you could order some like this in the link below, you will also need to find some for the 5 1/4's in the rear.
http://www.crutchfield.com/S-mnnNUy2...p?i=142SASC656
Old Apr 5, 2006 | 04:51 PM
Tuning69's Avatar
in the 2005 model, the speakers were rivited in place. You had to drill out the rivit, remove the speaker and baffle, and just screw new holes. Least thats what I did. Also try getting a 12X12 square of speaker dynamat and placeing that over the hole, then cut an X in the center of the hole, place the speaker in this to get sizing. Then push back the triangle pieces so that the stick to the inside of the door or back panel. Then put the speaker in place, screw in new self tapping screws and your done.
Old Apr 5, 2006 | 08:32 PM
Straylight's Avatar
Nice idea. Know where I can find a good how-to to disassemble my interior?
Old Apr 5, 2006 | 08:45 PM
Tuning69's Avatar
become a premium member, check out the tech section, xB repair manual, AV System. :smile:
archael666
Mar 19, 2019 11:52 PM
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
mdhyre
Dec 7, 2014 12:52 AM
